Broken blinker light caps
ttty2t1j3
#1 Unread post by ttty2t1j3 »
I broke both of my front blinker caps this last week and can't find a good place to buy them online. Are the often times producer standard? or do they vary by model?
coffee_brake
#2 Unread post by coffee_brake »
While a great variety of turn signal lenses are available, you should be able to match the ones you have at your local dealer through their parts distributors. My 90's honda signals, for example, are available locally at the nearby motorcycle shop (not even a dealership) through their parts distributor, Parts Unlimited, the signals are in the catalog on the front desk. They are the same lens, and MUCH cheaper than a "real" Honda lens. But even the OEM lens isn't that much.
Most bikes fall into this category. If your lenses are rare, you can easily replace the entire turn signal with something you like better.
Jenn S.
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
