fast and nasty carbon fouling
- Fargo360
- My Motorcycle: 1998 Honda VTR1000 SuperHawk 996
Ughh...I got the itch today and needed to get the bike running even though there is a wicked flood and we just had a blizzard. So I pulled it out and just started it up to make sure its running smooth for when the snow melts. I got it started up but noticed that it seems like one cylinder isn't running. I know there is fuel and air, so that leaves spark or compression. I pull the plug and notice that it is pretty well fouled, put it against the head and crank it...no spark. I pulled it away a little quick and it sparked against the head, but not to the pole. I had an extra plug and tried that, and it sparked fine, so I threw that one in there and fired it up. Ran great. I noticed I had a little exhaust leak so I shut it down and tightened the clamp. I fired it up again and it ran well for a few minutes then seemed a bit off, so I pulled that new plug and was a bit dismayed that it was carbon fouled already. I am under the impression that carbon fouling is resultant from rich mix, poor spark, poor timing, or poor compression. I am pretty sure I don't have a rich mix, so where should I start? Check the timing? Then maybe get new condensors? and finally pull it apart (not really wanting to do this)?
1976 Honda CBR360R/T
- Real Name: Ryan
Could be oil getting past your rings/valve guide seals.
Could be simply jetted too rich on that side.
Could simply be that your spark unit isn't strong enough to ignite the mixture in that cylinder!
I'd check your carbs first, then the spark unit, then the seals, then the rings.
- Fargo360
Well, I know the carbs are good. They both got a carb kit and a very thorough cleaning this winter. As for checking the spark unit, are you talking about the condensor? If I have to go after the seals, I'll probably just change them and do the rings while I'm at it.
- Real Name: Ryan
Yeah, check your condensor first.
I've seen it where it sparks but not under the high pressure of the cylinder, causing it to foul quickly. Make sure the spark is up to spec in the manual.
- coffee_brake
- Legendary 300
The nearest thing to a miracle cure for older bikes:
http://www.wgcarbs.com/index.php?option ... &Itemid=26
Folks who take the time to do it, swear by the Coil Mod. It bypasses the old wiring (which, due to its age, is adding to the resistance in the system) so the coils fire like they did when new. Also on this page somewhere are instructions for points bikes.
Jenn S.
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
AMA #658162
2005 Concours
2001 Vmax
1992 CB750
- Tennif Shoe
- Legendary 300
- Years Riding: 5
- My Motorcycle: VTX 1800c
very good write up never thought about itcoffee_brake wrote:The nearest thing to a miracle cure for older bikes:
03 Honda VTX 1800c
87 Yamaha TT350
86 Kawasaki Vulcan 750 (sold) Have fun in Mexico Mr. Vulcan!
YES my spellin sucks, get over it, or you can be my personal spell check
87 Yamaha TT350
