I was given a special chance to get a Honda ST1300P Police Bike today. Brand new with a fleet sale price. Does anyone have experienc with this bike. To me it's just awesome though I won't know for sure until tomorrow when I get to test drive one at the training facility. Does anyone have any thoughts on the bike or the civility of it.
The only problem with it is that I would need some $20,000 of work done on extending the length of my legs. I can just touch down with with both sets of my toes. The local dealer will do the warranty maintinance.
GAK! It's not a Harley. How will I be able to show my face around town.
Alex
It's good spelling but it Wobbles, and the letters get in the wrong places. WtPooh
My First Custom, Late 90's Sportster, Heavily Breathed On, Big Block, S&S HP Heads, Custom High Performance Pipes. Wickedly fast, Uncomfortable, Front end is a jackhammer. Age 18yrs, Still have the bike!
If I am not mistaken, but the British Police pulled their ST1300 (Paneuropean 1300) from service due to instability issues at high speed and returned to their older and mothballed ST1100's.
ceemes wrote:If I am not mistaken, but the British Police pulled their ST1300 (Paneuropean 1300) from service due to instability issues at high speed and returned to their older and mothballed ST1100's.
I've heard the same thing and found it to be true. it seems that when the British buit up the St1300p to full police specs, it developed a whole mess of nasty habits. It seems that the way it was designed there were few places to put all the lights and electronic equipment. Really knocked the balance of the bike all to hell. So far all the 2009 polce bikes that have been converted to Police specs haven't shown the same problems. I also know that there was a speed limiter put on all ST1300P thru 2007 (there was no 2008) and the 2009 doesn't have it. so go figure
Anyway, if it doesn't work out, the dealer has a ST1300a in ruby red that he'll let me try out. So we'll see.
Alex
I know this is an old topic, but I figured I would give my thoughts.
I had an '03 ST1300 for 5 years, and now have an '08 FJR1300. The ST1300 is a great bike, but my FJR is better overall.
The ST1300 does tend to have a bit of high speed instability. There tends to be a small amount of headshake above 125. Not bad enough to cause problems, and certainly not a tankslapper, but it is evident. Especially if it's windy, or if you pass a big truck going the other way and the wind blast hits you.
Not long after owing the bike, I found a sure fire way to find out if the rear tire is low. If it headshakes at all under 125 (except for maybe a harder than normal wind blast, and then only very temporary), the rear tire is low, typically below 35 PSI. I can imagine that weighing down the rear of the bike produces a similar effect, so increasing rear tire pressure above the recommended pressure may help the situation.
And despite the instability, it should in no way be enough to cause a problem. Based on my experience, I tend to believe the cops were being oversensitive to a problem that really isn't a bad problem. And I don't understand why they would want to go back to the ST1100. The ST1300 is much improved. It makes more sense to me to try a change of tire brand, or to experiment with higher tire pressures, install a stiffer rear spring/better shock, or maybe they can do like I did and raise the forks in the clamps. There very likely was something they could have done to improve the situation, instead of going back to the ST1100.
The ST1300 is definitely more unstable at higher speeds than the FJR1300, although it isn't bad. However, the FJR1300 is more unstable under hard braking from high speeds than the ST1300. But again, it isn't bad.
I don't know if the original poster bought the ST1300P, but it shouldn't be hard to remove the police equipment to lighten the bike.
