Delay in gas to power ?
Posted: Sat Jun 18, 2005 3:02 pm
by rickyh
When I give my motoryclce gas, it takes it a sec or two for the engine to respond.
For instance, if I'm in neutral and all of a sudden I give it some gas, for about a second, it'll be like I haven't touched it, stays the same sound and all, and then revs up.
It's like it's delayed or something.
This happens on and off with it.
Posted: Sat Jun 18, 2005 4:03 pm
by BuzZz
Stabbing in the dark...... jetting too rich(pilot jets)?, choke sticking?, air screws out of adjustment? carbs out of balance? time warp messing with your perception?
Posted: Sat Jun 18, 2005 4:17 pm
by rickyh
You'll have to forgive me, I have no mechanic background and am a newb to motorcycles
What does 'jetting to rich' mean ?
I don't think the choke is sticking, I don't know what air screws, or carbs are.
Posted: Sat Jun 18, 2005 4:36 pm
by BuzZz
Is this bike under warranty? That would be the best solution right now.
Jets are parts that regulate how much gas your engine gets and carbs mix the gas with air and the jets are in the carbs and you really should invest in a service manual for your bike if you plan on working on it yourself.
Trying to explain how to check/adjust these things right now would probably get you into more trouble than you got right now. A service manual and some googling for home mechanics sites will help you understand what is happening to your bike for any future adventures yo have.
Posted: Sat Jun 18, 2005 5:01 pm
by rickyh
Duly noted, I shall purchase a manual asap, also will do the googling thing, thinking about taking a motorycle mechanics course to, if nothing else to familiarize myself with terms and the like.
Posted: Sat Jun 18, 2005 5:16 pm
by BuzZz
'Zactly. Nothing wrong with working on your own bike(admirable, even), but you can save yourself a world of hurt if you arm yourself properly.
Posted: Wed Jun 22, 2005 3:07 pm
by rickyh
Well, ahem, I have resolved my issue.. uh hehe.. it was... that I had the gas guage set to reserve..so even though I had a full tank it wasn't going through all the way.
Posted: Sun Jun 26, 2005 4:27 am
by kar_the_terrible
wait.... even if you have a full tank *AND* its on reserve, you should still not be having throttle response problems.
Look up the manual in any case.
Posted: Sun Jul 03, 2005 8:35 am
by twowheelindave
sounds like a vapor lock, does it happen only after the bike is hot? Maybe a vacuum line is bad also??? Just a few quesses.
Posted: Sun Jul 03, 2005 9:20 am
by dr_bar
