72 tiger 650
lagimoo
72 tiger 650
#1 Unread post by lagimoo »
about had it with the elec on this thing ready to customize and use much simpler wiring if possible.? any idea or sites to get some ideas??
#2 Unread post by Johnj »
When you say simplify, do you mean with stock components or after market? You should have an 'oil in the frame' frame so don't drill or weld on it. Are you going to run turn signals? I'll try to work something up ok.
lagimoo
72 tiger 650
#3 Unread post by lagimoo »
stock or not im at the point where lucas wiring(prince of darkness can stuff it) im ready for a little less head aches. NH requires tail lights for inspection unless you know someone (wink wink). i would greatly appreciate any and all help on this.
#4 Unread post by Johnj »
Here's a simple wiring diagram. It uses all the stock components.
