Coil/Ignitor 1981 XJ550R
DOCDOTY
#1 Unread post by DOCDOTY »
I have a 1981 XJ550R Yamaha. It used to run just fine. It sat for a year. Now when I ride it, it will run good for about 15 minutes each time then cut off. If I let it sit for a little while I can start it up again ride for another 15 minutes and then it will cut off. I think it might be the ignitor or coil assembly. Any help would be appreciated.
#2 Unread post by Johnj »
Have you checked the fuel tank vent? Try this, take the bike out and ride it till it dies. Open the fuel tank. Did you hear a whoosh of air?
