Squashed nut
guitarguy1
Squashed nut
#1 Unread post by guitarguy1 »
Hey guys,
I got my hands on a 1983 Honda FT500 and i have a problem I need some help with.
I've taken the bike down to the frame to repaint, replace, and rebuild along with cleaning the rust off of the bike. Unfortunatly one of the nuts has been squashed and sanded down smooth. My best guess is that someone had to slide on it. None of the sockets on my wrench will fit over it, nor would they be able to grip it if they could. It's been formed into an egg shaped chunk. And so I'm stuck.
Any thoughts on how to get it off? Or will I need to take my torch to it and chop it off and try to get the shaft out?
Any help is greatly appreciated
When the rich wage war it's the poor that die
ceemes
Real Name: a big secret
Re: Squashed nut
#2 Unread post by ceemes »
guitarguy1 wrote:Hey guys,
First make sure it is actually a nut and can be removed. Second, vice grips are you friend.
guitarguy1
#3 Unread post by guitarguy1 »
I've tried them and they wont grip. I'ts actually rounded all over and in a wierd shape. and I lied, sorry. Its not the nut, its the actual bolt head.
#4 Unread post by Johnj »
Get one of those rounded head tools at Sears. They work for Bob Vila.
flynrider
#5 Unread post by flynrider »
If it's a bolt head, you could try cutting a slot in it with something like a dremel tool. Then use an impact driver with a tight fitting bit.
Bikin' John
'93 Honda CB750 Nighthawk
ChriswithaHawk
Re: Squashed nut
#6 Unread post by ChriswithaHawk »
I would recommend saturating whatever it is with WD40 before you do attempt to break it free, seems to work miracles on seized up bolts.
Couldnt you also drill a hole in the middle of the nut and then use an easy out?
If firearms are outlawed, then only outlaws will have firearms
csspostal
Real Name: Tom
Re: Squashed nut
#7 Unread post by csspostal »
I seen the title and mind went total different direction. I had the same issue but it was on a toilet seat. :(
guitarguy1
Re: Squashed nut
#8 Unread post by guitarguy1 »
hey guys, thanks for the suggestions, i ended up putting a crescent wrench on it and using a hammer on teh other end of the wrench. it took about half an hour to get the darned thing out
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
Re: Squashed nut
#9 Unread post by Gummiente »
csspostal wrote:I seen the title and mind went total different direction. I had the same issue but it was on a toilet seat. :(
Yep, you'll fit in here no problem. :thumbsup:
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
HYPERR
Re: Squashed nut
#10 Unread post by HYPERR »
Is the nut still on there? :shock:
EDIT: Oh I see you got it off. :kicking:
