Squashed nut
Posted: Fri Oct 16, 2009 2:23 am
by guitarguy1
Hey guys,
I got my hands on a 1983 Honda FT500 and i have a problem I need some help with.
I've taken the bike down to the frame to repaint, replace, and rebuild along with cleaning the rust off of the bike. Unfortunatly one of the nuts has been squashed and sanded down smooth. My best guess is that someone had to slide on it. None of the sockets on my wrench will fit over it, nor would they be able to grip it if they could. It's been formed into an egg shaped chunk. And so I'm stuck.
Any thoughts on how to get it off? Or will I need to take my torch to it and chop it off and try to get the shaft out?
Any help is greatly appreciated
Re: Squashed nut
Posted: Fri Oct 16, 2009 2:43 am
by ceemes
guitarguy1 wrote:Hey guys,
First make sure it is actually a nut and can be removed. Second, vice grips are you friend.
Posted: Fri Oct 16, 2009 3:36 am
by guitarguy1
I've tried them and they wont grip. I'ts actually rounded all over and in a wierd shape. and I lied, sorry. Its not the nut, its the actual bolt head.
Posted: Fri Oct 16, 2009 3:54 am
by Johnj
Get one of those rounded head tools at Sears. They work for Bob Vila.
Posted: Fri Oct 16, 2009 11:15 am
by flynrider
If it's a bolt head, you could try cutting a slot in it with something like a dremel tool. Then use an impact driver with a tight fitting bit.
Re: Squashed nut
Posted: Sat Mar 06, 2010 1:40 am
by ChriswithaHawk
I would recommend saturating whatever it is with WD40 before you do attempt to break it free, seems to work miracles on seized up bolts.
Couldnt you also drill a hole in the middle of the nut and then use an easy out?
Re: Squashed nut
Posted: Sat Mar 06, 2010 4:08 am
by csspostal
I seen the title and mind went total different direction. I had the same issue but it was on a toilet seat. :(
Re: Squashed nut
Posted: Sat Mar 06, 2010 4:23 am
by guitarguy1
hey guys, thanks for the suggestions, i ended up putting a crescent wrench on it and using a hammer on teh other end of the wrench. it took about half an hour to get the darned thing out
Re: Squashed nut
Posted: Sat Mar 06, 2010 5:30 pm
by Gummiente
csspostal wrote:I seen the title and mind went total different direction. I had the same issue but it was on a toilet seat. :(
Yep, you'll fit in here no problem. :thumbsup:
Re: Squashed nut
Posted: Sat Mar 06, 2010 5:45 pm
by HYPERR
Is the nut still on there? :shock:
EDIT: Oh I see you got it off. :kicking:
