Help Ignition Problems D2 VN1500
aw58
My Motorcycle: 1997 kawasaki vn1500 d2 classic
#1 Unread post by aw58 »
Hi,
I have no ignition lights, no electrics at all . All fuses ok, just bought a new battery as the old one was prone to failure in cold weather.
Checked all my connections on the fuse box.
Running fine after having new stainless exhausts made. Removed the speedo to check the cable connection as no speed being recorded - replaced and now no electrics.
any Ideas???
If you can see the tops of the mountain's it's going to rain.
If you can't - it's raining.
All Characters and events here are allegedly fictitious...Any resemblance with either dead or living is purely co-incidental
And don't ride faster than your Guardian Angel can fly
jaskc78
My Motorcycle: N/A
Re: Help Ignition Problems D2 VN1500
#2 Unread post by jaskc78 »
was there possibly an intermittent short in the speedo causing the speed to not be reported that became a constant short when you removed it and jiggled the wires around in the process? only thing i can think of if you've checked the charge on the battery since you lost the electrics.
