Bike Maintenance
hyosung09
Real Name: Andrew
Years Riding: 1
My Motorcycle: 2009 Hyosung GV250
Bike Maintenance
#1 Unread post by hyosung09 »
Not being mechanically minded I need help with a rear brake light problem.
I have changed the globe, but it still is not working.
What should i be checking next.
jaskc78
My Motorcycle: N/A
Re: Bike Maintenance
#2 Unread post by jaskc78 »
wire connections and fuses
PeterTrocewicz
#3 Unread post by PeterTrocewicz »
I'm assuming that it's the brake light comes on with front lever, but not the rear pedal when you say "rear brake light". Both should work. If it's just the pedal that won't turn on the light, it's probably the switch. It,s ususally right above the pedal, and is pulled on by a spring hooked to the pedal.Sometimes th spring loses its tension, or comes off, or the switch, which sits in a socket on the frame, gets cockeyed and won't come on. The switch has an adjusting nut on it, which makes up for a sacked spying by moving the switch further away from the pedal when you tighten it. Sometimes the switch just stops working. Try these things before worrying about anything else.
I don't want a pickle, I just wanna ride on my motorsickle
