honda hawk 750 1991
- Tricycle Squid
- Real Name: herman
- Years Riding: 8
- My Motorcycle: Year/Make/Model1991 honda hawk 750
honda hawk 750 1991
i cleaned the carburator change sparkpulgs oil and filter new fuel hose i'm having problems with the throtle is shutting of when u try to ride it , it dies out it seems that it's getting air in the lines i dont no when u try to throtle it shuts of it's not idleing well
- BuzZz
- Real Name: Never Used Here
- Years Riding: 47
Re: honda hawk 750 1991
It sounds like the bike is either getting too much fuel, or not enough, hard to say from the description.
Two possibilities come to mind. Either the carb cleaning has gone wrong, or maybe the fuel filter is too restrictive.
When the carbs were cleaned, did you put all the needle clips back in the same place? All the adjustment screws back to their original settings? Did you maybe clean the jets too aggressively and enlarge them?
The fuel filter may be the problem (did it have one before and is the new one a correct replacement?) but it would have to be pretty restrictive to cause fuel starvation.
Are the air filters clean? Did a rag or something get left in the intake tract someplace?
No Witnesses....
