The Infinite # of Motorcycle Commandments
#1 Unread post by High_Side »
I'll start us off with a couple of Motorcycle Commandments to share the wealth of knowledge that resides in the collective grey-matter of the TotalMotorcyclers. To do your part, simply add your own to the existing commandments above like this:
1.) Assume the bastards will never see you.
Re: The Infinite # of Motorcycle Commandments
#2 Unread post by High_Side »
2.) If you wear a yellow vest and have loud pipes in hopes that people will see you, see #1
#3 Unread post by High_Side »
3.) Yellow vests do not look cool :P
#4 Unread post by High_Side »
4.) Never believe anything that you read on an internet motorcycle forum!
#5 Unread post by High_Side »
5.) Never ride faster than your line of sight allows
#6 Unread post by High_Side »
6.) Thou shalt be OK to covet thy neighbors motorcycle, however thou shalt not buy the exact same motorcycle as this will "pee" them off.
#7 Unread post by High_Side »
....take it away.....
#8 Unread post by Wrider »
7.) Ride like half the people don't see you, and the other half want to kill you.
fireguzzi
Real Name: Trevor
#9 Unread post by fireguzzi »
8.) Take number 1 and 7 and turn it into a mantra to chant to yourself while riding anywhere other then your driveway.
HYPERR
#10 Unread post by HYPERR »
9.) You can ride fast and you can ride slow, but never ride in a hurry.
