2011 Norton Commando 961 Sport
http://www.totalmotorcycle.com/photos/2 ... 1Sport.htm
Frame
- Frame: Steel tubular with integral oil tank
- Swing arm: Twin-sided steel construction
- Wheelbase: 1420mm (55.9 in)
- Rake: 24.5 degrees
- Trail: 99mm (3.9 in)
- Front suspension: 43mm Ohlins RWU - Adjustable preload, compression damping.
- Rear suspension: Ohlins reservoir-style twin shocks - Adjustable ride height, preload, compression
- Front wheel: 36 spoke 3.50 x 17” Chrome Rim
- Rear wheel: 40 spoke 5.0 x 17” Chrome Rim
- Front tyre: 120/70 x 17”
- Rear tyre: 180/55 x 17”
- Front wheel travel: 115mm (4.53 in)
- Rear wheel travel: 100mm (3.94 in)
Brakes & Hydraulics
- Front brakes: Full Brembo system, twin Brembo 320mm semi-floating hi
carbon stainless steel discs, Brembo 4 piston “Gold Line” axial callipers
- Rear brakes: Full Brembo system, single Brembo 220mm disc, Brembo 2 piston “Gold Line” calliper
- Brembo “Gold Line” front brake master cylinder
- Brembo “Gold Line” hydraulic clutch master cylinder
- Brembo rear brake master cylinder
- Brembo hydraulic clutch actuation slave cylinder
Transmission
- Gear box: constant mesh 5 speed
- Final drive: 525 “O” ring chain
- Clutch: Wet multi-plate hydraulic lifter
- Electric start Power Assembly
- Engine type: New engine developed by Norton and F1 engine builders, MCT of Oxfordshire, England. Parallel twin with push-rod valve actuation, dry sump, 3 bearing crank and balancer shaft.
- Displacement: 961cc
- Cooling system: Air
- Valve actuation: Push rod, 2 valves per cylinder
- Bore x stroke: 88mm x 79mm
- Compression ratio: 10.1:1
- Power: 80PS @ 6500RPM
- Torque: 90Nm @ 5200RPM
- Ignition: Crank fired electronic
- Euro 3 compliant with electronic fuel injection and multiple 3 way catalytic converter
Electronics & Controls
- Charging system: 300 watt hi-output charging system
- Instrumentation: Norton electronic analogue speedo & tachometer
Miscellaneous
- Fuel tank capacity: 17 litres (4.5 US gallon)
- Dry weight: 188kg (414.5 lbs)
- Seat height: 813mm (32 in)
- Steering: Fully machined billet yokes, triple clamp lower yokes
- Handlebars: Tubular steel in chrome
Colour Options
- Black & Gold
- Red & Gold
- Yellow & Black
- Silver, Red & Black
