Newbie restoration question 3
- Regular
- Real Name: Richard
- Years Riding: 2
- My Motorcycle: 1985 Kawaski ninja
On the 1985 ninja 600, there is some type of electrical component attached to the tireside of the rear fender directly under the passenger seat, (but closer to where the license plate would mount). It is feed by two wires from what appears to be a relay. The one I have on my bike is damaged and corroded beyond repair, but is not associated with the signal or braking function in any regard. I didn't even know it existed until I started tearing down the seating area to access the brake light for a simple bulb swap (after a summer of riding).
It is purpose built, and snapped into factory clips. I don't know why it was ever engineered for there due to exposure to any crude cast from the rear tire...but alas, here we are.
Little help
Hakx
Little help
Hakx
- Years Riding: 32
Re: Newbie restoration question 3
I think a photo might be needed... any chance of putting one up of this part and the area it's in?
2023 Motorcycle Model Guides
- Johnj
- Real Name: Johnny Strabler
I think a manual is required for this.
![Image](http://i64.tinypic.com/wsu2on.jpg)
- Regular
- Years Riding: 2
Never mind!
I chased the wiring, and it terminated at a hidden toggle switch. Once I removed it from the bike I looked a little closer, and it appears that a previous owner wired up a small light over the rear tire for that "TRON" look LOL.
I am really starting to hate electrical tape. They're better ways to restore the integrity of chasis wiring or sealing splices than wrapping the SH*T out of it with that stuff!!
- Johnj
Heat-shrink tubing and a heat gun are your friends.
- JC Viper
- Real Name: JC
- Years Riding: 7
- My Motorcycle: 1984 Kawasaki GPz900R
They also have liquid electrical tape and I've found it works very well for a clean look and effective fix when I had to do wiring on the Vulcan.
Congrats on the old bike. I've an '84 Ninja 900R but the wiring is pristine.
![Image](http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs397.ash2/67545_1411490852559_1391137075_30898572_6204304_n.jpg)
- Regular
- Years Riding: 2
I'm an electronics technician by trade, but the previous owner wasn't...hence my disdain towards e-tape. I have already cleaned up any aftermarket attemps of splicing with solder and heat shrink, & managed unsecured harness with split tube and tie mounts. All indicator bulbs are now LED, and the Bi-Xenon HID headlight conversion went swimmingly.
Man...I can't wait for this seemingly endless winter to, well....END!!
- JC Viper
- Real Name: JC
- Years Riding: 7
Bi-xenon HID headlight? what brand is it? I'm interested in upgrading from the H4 setup.
- Regular
- Years Riding: 2
Ebay. I don't remember the brand, but it was of European origin from a US vendor. They are very common, but you have to mindful of the conversions with the cheap ballast out of Hong Kong (you want a digital ballast). My high beam is a bright and crisp 6K diamond white.
- JC Viper
- Real Name: JC
- Years Riding: 7
Yeah, I bought an 6K HID kit from an actual bike store in Manhattan and the ballast looks quality but instructions are not. Currently the bike uses an H4 which does both low and high beams and been hesitant to install the HID kit because I need both hi and lo. I've never ventured into modding my headlights, everything else yes (tail lights will be using flexible LED strips from Radiantz and currently working on making flush mount turn signals that look good and are functional with the hazard switch).
