Hi Sunshine! Thank you for the warm welcome. Good to be back with you guys.
Wrider, YOU ARE THE MAN! Thank you so much for the manual. Thank you, thank you, thank you.
This is the red light that stays on:
It also says "CHEC" next to it for a few seconds right after starting. While "CHEC" goes away, the red light stays on.
As for the shifting to neutral, I will have to try what you mentioned about the alternate shifting method. I did notice the clutch is a little loose at the beginning of the pull. They had to put a new clutch handle on just before picking it up because someone broke the original. It seems to shift just fine, however. When I'm rolling the bike while off, I do notice a tiny bit of... resistance, but it does roll with clutch engaged, and does not pull forward while in running in gear with the clutch engaged.
I may have to make a short youtube clip to show exactly what I mean. I'm not fluent enough in the lingo to explain.
So much appreciated,
Matt
