yamaha tmax tires.
dirt dobber
Real Name: james
yamaha tmax tires.
#1 Unread post by dirt dobber »
my 09 tmax came with bridge stones, replace front with same at 5100 miles because of wear on left side & cupping i guess it's called had flat places on it, now at 7700 2600 later it's showing it's beginning to do the same. i live in no. alabama & started riding more to the left side of road because of crown.
question, has any one experience this & what did you do to solve or help to get more mile. rear show wear in center But, still ok. :P
Re: yamaha tmax tires.
#2 Unread post by Wrider »
If it's got cupping you need to check it's pressure more often. Or if you already do check it regularly, you need to have your front suspension adjusted for your weight/riding style.
Marvin
Real Name: Bart
My Motorcycle: 2009 Yamaha TMAX, 2005 Yamaha FZ6
#3 Unread post by Marvin »
Thats one disadvantage of owning a scooter, all scooters are hard on tires due to the smaller rim size, less rubber on the roads and the higher weight of the machines, one advantage is the Tmax uses the bigger 15" diameter tires were the Burgman and Silver Wings use the 14".
I have 3000 miles on my Tmax and my stock Bridgestone's are still like new and it doesn't look like there are many other brands in the sizes that fit the Tmax, so when the time comes to replace them I will get another set of Bridgestone.
I am a stickler and I check my air pressure before every ride and I always go 5 psi higher than recommended
2009 Yamaha TMAX
2008 Suzuki King Quad 750AXI
