How to check clutch on used bike?
flw
#1 Unread post by flw »
I'm going to look at a used bike and want to be sure the clutch is not almost dead.
In a car with a manual trans, you find a (big) tree and make solid contact with the trunck. Then at idle, slowly let the clutch out. It should kill the engine and show you have a solid clutch. But if it allows the engine to rotate at all the clutch is almost dead.
Now on a bike, how can I test the clutch to be sure its not on deaths door step?
Thank
Goldwing 1500se '98
VN500 LTD '07 Sold
Re: How to check clutch on used bike?
#2 Unread post by Wrider »
You could do the same thing, except rev it a little. Hold it around 2000 and let the clutch out slowly while sitting on the bike so the tire doesn't try to spin.
Or go out and rev it to redline, drop the clutch, and if it wheelies you're good! haha
flw
#3 Unread post by flw »
Holding it at 2k seems bit high, no? I may buy the ibke and don't want to damage a otherwise good bike.
Goldwing 1500se '98
VN500 LTD '07 Sold
gsJack
My Motorcycle: 02 GS500
#4 Unread post by gsJack »
flw wrote:Holding it at 2k seems bit high, no? I may buy the ibke and don't want to damage a otherwise good bike.
Hold the rear brake tight to prevent wheel spin, rev engine, let clutch out slowly to stall engine. About 2000 rpm sounds good to me, I do it that way. Letting clutch out slowly will help induce clutch slippage if clutch is marginal, good clutch will kill engine.
#5 Unread post by Wrider »
Yup, we usually hit 3K in the shops while testing clutches.
HYPERR
#6 Unread post by HYPERR »
flw wrote:I'm going to look at a used bike and want to be sure the clutch is not almost dead.
Thank
I'm feeling a strong case of déjà vu here...
Wasn't there an almost identical thread here recently? :humm:
EDIT: Suspicion confirmed :laughing:
Hondagirl
#7 Unread post by Hondagirl »
haha, and almost all the same people replied too!
Well, flw yer not the only one, lol, I always need to be told at least twice before I get-it-mechanics and even then.. :confused2:
Honda Motard XR400
flw
#8 Unread post by flw »
Holding the idle to about 2k plus worked well as a simple clutch test.
I'm not sure about the subject of clutch testing on a motorcycle has come up before? Or maybe I'm just forgetful.
Thanks to those that responded.
Goldwing 1500se '98
VN500 LTD '07 Sold
storysunfolding
Years Riding: 22
#9 Unread post by storysunfolding »
flw wrote:Holding the idle to about 2k plus worked well as a simple clutch test.
Someone should have clicked the link :laughing:
My Blog
Grasp life by the handlebars
HYPERR
#10 Unread post by HYPERR »
:shifty:
