So it looks like I'm a little low on oil in my bike (I can see it in the pan but it doesn't register on the dipstick)
the place that works on my bike said they use 20-50 oil, now does it matter what brand I use to top it off? http://www.partsamerica.com/ProductDeta ... number=743
is what I was looking at.
Thanks in advance.
Oh and there aren't any real markers on my dipstick, I just saw a couple of tiny dots so i'm not sure how much oil I should put in it, I don't want to put too much in but I don't want too little either.
Thanks again.
Oil
Oil
My bike: '99 HD Sportster 1200
- BuzZz
- Real Name: Never Used Here
- Years Riding: 47
All brands of oil that meet SAE spec are compatable with each other. Home brewing your own mixture is not recommended but adding one brand to another to top off is not going to hurt anything. Just keep the weight the same.
Those 2 dots on your dipstick are markings for the level. You want the level to fall between them, closer to the top is full, closer to the bottom is time to add.
No Witnesses....
I would stongly suggest you take a look at Amsoil for your bike...and other equipment too. Amsoil just introduced new oils for motorcycles, that literally blow the competition away with respect to rust protection(important during storage) and wear protection! Plus if you have a filter on your bike, you can use the oil 2X longer than the manufacturer recommends....all guranteed by Amsoil. Check out this website: www.lubedealer.com/jtubbs.
- mustangski
- Wizzard
- Legendary 1000
If you are not going to change your oil merely add to it , make damn sure you know whether it is detergent oil or synthetic oil before you do any thing .
Regards, Wizzard
Regards, Wizzard
Guys, I gotta admit, that I am an Amsoil Dealer, but..there is a story behind it. I was doing some research on motor oils a few years ago, and one brand, Amsoil, seemed to be rated much higher than the rest. I started doing more research, and was impressed by what I learned. Anyway, before I became a dealer, I tried the oil for a year. There is nothing on the market any better. Remember, you get what you pay for! I am now changing my oil once a year, in my personal vehicles. I change the filter at six months. Amsoil hopefully will introduce a one year oil filter soon. This company never ceases to amaze me. They have great two cycle oils, too. My son has a pocket bike, and he is using Amsoil Sabre Professional at a 100:1!! The manufacturer recommends a 40:1. I am using the Sabre too, in all of my lawn equipment, at the same ratio, with no problems. They are truly on the cutting edge of lubricant technology. Plus Amsoil gurantees that in the proper application, if the oil is determined to cause a failure when used as recommended by Amsoil..they will pay to repair or replace your engine! This guarantee is available by www.lubedealer.com/jtubbs. Just click on the link at my website to learn more about Amsoil. I am changing my oil once a year! I know I am saving money too. The cost of a one year Amsoil change is about $40-50 dollars! So, if you have your oil changed for you, you are saving money! Cost above includes a heavy duty Amsoil Filter. I was a strict Castrol fan until a few years ago! Ok, sorry for the selfless promotion, but if you have questions, please email me! Take the time and do your own research.....I think you will reach the same conclusion that I did. Amsoil stands alone. Don't forget, too, that in your motorcycles, Amsoil can be used twice as long, with engines that have oil filters!
