I'm an idiot.
vampfiend687
Real Name: Stan
My Motorcycle: 82 Suzuki GS750
I'm an idiot.
#1 Unread post by vampfiend687 »
So a couple weeks ago, I bought an 82 Suzuki GS 750. I got home from getting my motorcycle permit and somehow lost the keys. I called the local locksmith and he was gonna charge me $200 if he had to come out and make a key for the bike or $30 if I brought him the ignition switch. I was wondering if anyone knew how to get the ignition switch off and what tools I might need.
"There comes a point in a man's life in which he must be tempted to spit upon his hands, hoist the black flag and begin slitting throats."
-H.L. Mencken.
Re: I'm an idiot.
#2 Unread post by High_Side »
I'm not sure about Suzukis of that era but with 80s Hondas at least you could get them from a dealer if you knew the serial number. It's long shot, but worth a shot nonetheless.
HYPERR
Re: I'm an idiot.
#3 Unread post by HYPERR »
I'm not sure about your exact bike but aren't most japanese bike ignition switch of that era mounted with like two phillips screws? The wiring is usually a plastic quick disconnect as well.
Re: I'm an idiot.
#4 Unread post by Wrider »
Yup, yours are mounted from underneath with two bolts that come up from underneath the triple tree and screw through the ignition into it.
HYPERR
Re: I'm an idiot.
#5 Unread post by HYPERR »
Wrider wrote:Yup, yours are mounted from underneath with two bolts that come up from underneath the triple tree and screw through the ignition into it.
I hope for his sake, it's a 8mm or 10mm bolt and not a phillips. :laughing:
Re: I'm an idiot.
#6 Unread post by Wrider »
:laughing: That's for sure!
vampfiend687
Real Name: Stan
Re: I'm an idiot.
#7 Unread post by vampfiend687 »
Thanks guys, I probably wont get a chance to work on it until this weekend but I should be able to solve my problem
-H.L. Mencken.
Re: I'm an idiot.
#8 Unread post by Wrider »
vampfiend687 wrote:Thanks guys, I probably wont get a chance to work on it until this weekend but I should be able to solve my problem
If you decide to go the cheap route, you can get a different gas cap and wire in a pushbutton/flip switch somewhere hidden and not need a key at all!
HYPERR
Re: I'm an idiot.
#9 Unread post by HYPERR »
You do realize that once you have the new keys made, the old ones will show up..... :lolsign:
vampfiend687
Real Name: Stan
Re: I'm an idiot.
#10 Unread post by vampfiend687 »
if they do show up, I'll have a new set of spare keys and my favorite keychain back
-H.L. Mencken.
