http://www.totalmotorcycle.com/motorcyc ... ntyTwo.htm
Authentic '70s chopper attitude meets modern power and premium H-D styling in this bare-bones, lowrider-inspired radical custom
The Harley-Davidson® Seventy-Two motorcycle is a metal flake dream machine, a Sportster® motorcycle on a trip back to the days when the cool kids rode Sting-Ray bikes and the big boys parked choppers in a row on the curb. Those motorcycles were long and lean; candy-apple colour and gleaming chrome shimmering in hazy summer sunlight. From its Hard Candy Big Red Flake paint and ape bars to its narrow whitewall tires, the Seventy-Two model is a respectful nod to that era, and to the influence of the custom culture that still percolates today along Whittier Boulevard, the legendary cruising street in East Los Angeles, also known as Route 72. A new generation of custom builder is tapping into that era and making a fresh statement, not just in California but in garages across the country, even around the world.
"In creating the Seventy-Two [motorcycle], we were also inspired by the vibe of the early chopper era," says Frank Savage, Harley-Davidson Manager of Industrial Design. "Those bikes were colourful and chromed, but also narrow and stripped down to the essentials. You look at period examples and they are almost as simple as a bicycle. It's a custom style that's very particular to America and that California scene."
Metal flake, an iconic design element of the 70s, appeared in everything from dune buggy gel coat to vinyl diner upholstery, and on custom motorcycles. Harley-Davidson Motor Company brings the sparkle back on the Seventy-Two motorcycle with Hard Candy Big Red Flake paint. This new finish is created by applying a black base coat, followed by a polyurethane system that carries hexagon-shaped flakes that are more than seven times the diameter of the metal flake that is used in typical production paint. Each flake is coated with a thin aluminium film and then tinted red. Four applications of clear coat, combined with hand-sanding, create a smooth finish over the flakes.
"The final touch to the Hard Candy Big Red Flake paint is a logo on the tank top and pinstripe scallop details on both fenders," says Savage. "Each was originally created by hand, and we recreated that art in a decal for production, so they still have the appearance of hand-applied graphics in that they are not exactly perfect. The graphics are then covered with a final clear-coat application."
A solo seat shows off more of the paint exposed on the Seventy-Two motorcycle. The powertrain is finished in grey powdercoat with chrome covers and a new round air cleaner with a dished cover. A classic Sportster® 2.2-gallon "peanut" fuel tank adds a final period touch to the motorcycle.
Based on the Harley-Davidson Sportster platform, the Seventy-Two™ introduces Hard Candy Big Red Flake, a sparkling, metal flake color option applied to the fuel tank and fenders. A solo seat and side-mount license plate bracket leave much of the chopped rear fender – and more of that paint – exposed on the Seventy-Two. The Evolution® 1200 cc V-Twin powertrain is finished in Gray powdercoat with chrome covers and a new round air cleaner with a dished cover. A classic Sportster 2.1-gallon fuel tank, narrow white wall tires, Chrome Laced wheels, and high mini-ape handlebar complete a look that nods to chopper custom motorcycles of the 1970s.
2012 Harley-Davidson XL1200V Seventy-Two Model Highlights
• Paint color options: Hard Candy Big Red Flake with period pinstripe details on fenders and fuel tank, Black Denim, Big Blue Pearl
• Powertrain is finished in Gray powdercoat with chrome covers
• Chrome, eight-inch round air cleaner cover
• 2.1-gallon Peanut Tank with lightening hole mounting bracket
• Dunlop® white wall 21-inch (MH90-21) front and 16-inch (150/80B16) rear tires
• Chrome Laced wheels
• Stainless steel mini-ape handlebar, mounted on a two-inch high riser
• Chopped rear fender
• One-piece, Sportster® classic solo seat
• Side-mounted license plate
• Solo seat with black textured vinyl cover
• Handlebar-mounted speedometer with chrome cup
• Chrome rear fender struts
• Chrome coil-over pre-load adjustable rear shocks
• Forward foot controls
2012 Harley-Davidson XL1200V Seventy-Two - USA Specifications/Technical Details
US MSRP Price: Color Option $10,499; Hard Candy Big Red Flake Option $11,199 USD
Canada MSRP Price: Color Option $11,919; Hard Candy Big Red Flake Option $12,719 CDN
DIMENSIONS
Length 89.4 in. (2270 mm)
Overall Width 36.0 in. (915 mm)
Overall Height 47.6 in. (1210 mm)
Seat Height:
• Laden2 26.6 in. (675 mm)
• Unladen 28.0 in. (710 mm)
Ground Clearance 4.7 in. (119 mm)
Rake (steering head) 30.1°
Fork Angle 30.1°
Trail 5.3 in. (135 mm)
Wheelbase 60.0 in. (1524 mm)
Tires (Dunlop® Harley-Davidson® Series, narrow whitewall):
• Front – D402F MH90-21 54H
• Rear – D401 150/80B16 71H
Fuel Capacity 2.1 gal. (7.9 L) (warning light at approximately 0.65 gal.)
Oil Capacity (w/filter) 2.8 qts. (2.6 L)
Transmission Capacity 1.0 qt. (.95 L)
Weight:
• As Shipped 545 lbs. (247.2 kg)
• In Running Order 555 lbs. (251.7 kg)
• Gross Vehicle Weight Rating 1000 lbs. (453.6 kg)
• Gross Axle Weight Rating
• Front 335 lbs. (152.0 kg)
• Rear 665 lbs. (301.6 kg)
ENGINE
Engine Air-cooled, Evolution® Valves Pushrod-operated, overhead valves with hydraulic, self-adjusting lifters; two valves per cylinder
Bore x Stroke 3.5 in. x 3.812 in. (88.9 mm x 96.8 mm)
Displacement 73.3 cu. in. (1200 cc)
Compression Ratio 9.7:1
Fuel System3 Electronic Sequential Port Fuel Injection (ESPFI)
Air Cleaner Paper cartridge type
Lubrication System Dry-sump
DRIVETRAIN
Primary Drive Chain, 57/38 ratio
Final Drive Belt, 68/29 ratio
Clutch Multi-plate, wet
Transmission 5-speed Gear Ratios (overall): U.S.
• 1st 9.315
• 2nd 6.653
• 3rd 4.948
• 4th 4.102
• 5th 3.517
CHASSIS
Frame Mild steel, tubular frame; circular sections; cast junctions
Swingarm Mild steel, rectangular tube section, stamped junctions; MIG welded
Front Forks 39 mm
Rear Shocks Coil-over; preload dual-adjustable
Wheels4: Chrome Steel Laced
• Front 21 in. x 2.15 in. (533 mm x 55 mm)
• Rear 16 in. x 3 in. (406 mm x 76 mm)
Brakes:
• Caliper Type Dual-piston front, single-piston rear
• Rotor Type (diameter x width): Patented, uniform expansion rotors
• Front 11.5 in. x .2 in. (292.1 mm x 5.1 mm)
• Rear 10.24 in. x .28 in. (260.1 mm x 7.1 mm)
Suspension Travel:
• Front Wheel 5.69 in. (145 mm)
• Rear Wheel 2.12 in. (54 mm)
PERFORMANCE
Engine Torque5 (per J1349):
• North America 73 ft. lbs. @ 3500 RPM (99 Nm @ 3500 RPM)
Lean Angle (per J1168):
• Right 28.6°
• Left 29.8°
Fuel Economy6
(EPA urban/highway test) 48 mpg (4.9 L/100 km)
ELECTRIC
Battery (per Battery Council International Rating)
Sealed, maintenance-free, 12V, 12 amp/hour, 200 cca
Charging Single-phase, 30-amp system (357W @ 13.5V, 2000 RPM, 405W max power @ 13.5V)
Starting 1.2 kW electric with solenoid shift starter motor engagement
Lights (as per country regulation):
• Headlamp (quartz halogen) 55-watt low beam, 60-watt high beam
• Turn Signal Lights 28W self-canceling
• Rear Tail/Stop/Turn Signal Lights 8W/28W per lamp
• Indicator Lamps: High beam, neutral, low oil pressure, turn signals, engine diagnostics, low fuel warning, low battery, security
system7 (optional)
WARRANTY
Warranty8 24 months (unlimited mileage)
Service Interval9 First 1000 miles (1600 km), every
5000 miles (8000 km) thereafter
