lately my bike is needing brake line bleeding a lot. help?
VermilionX
Super Legendary 5000
#1 Unread post by VermilionX »
i estimate maybe every 5 months or so.
before that it was needed every month. so my mechanic replaced my brake lines to braided and that lasted for a whole year until i needed bleeding again.
now, it seems like im needing it more often again.
my mechanic said i should replace the... i forgot what it's called but it's the part that the brake lever is connected to.
does that sound right? any ideas why this is happening?
MmeMagpie
Real Name: Andrea Robinson
My Motorcycle: 2004 Honda Shadow Aero VT750C
Re: lately my bike is needing brake line bleeding a lot. hel
#2 Unread post by MmeMagpie »
The master cylinder?
SInce it controls the pressure in your brake lines (allowing you to brake) I think it's kinda important to replace it if it's worn out.
Ooooooh. Shiny!
VermilionX
#3 Unread post by VermilionX »
MmeMagpie wrote:The master cylinder?
yes, master cylinder.
my bike is an 06 model so i guess that doesn't sound bad to replace it now.
thanks.
#4 Unread post by Wrider »
You won't need to replace it, but rebuilding it isn't a bad idea. Same with the front calipers.
#5 Unread post by dr_bar »
How the heII do you wear out a Master cylinder???
VermilionX
#6 Unread post by VermilionX »
Yeah i dunno how.
He just told me that replacing that should guarantee to fix this problem.
fireguzzi
Real Name: Trevor
#7 Unread post by fireguzzi »
I think your mechanic might should find the actual source of leaking instead of just replacing things and seeing if it works. Thats a waste of your money. It is more cost effective to rebuild the master cylinder then to replace.And it being that your bike is only 6 years old i doubt if it needs replacing. But he needs to check the lines and the caliper as well before jumping to conclusions and spending your money.
VermilionX
#8 Unread post by VermilionX »
Alright. Ill have him check out other possibilities.
Marvin
Real Name: Bart
My Motorcycle: 2009 Yamaha TMAX, 2005 Yamaha FZ6
#9 Unread post by Marvin »
DUHHHHH!!!!! I can't believe none of you so called ,,,,experts,,, know this?????
you have to "BACK BLEED"
there's a check valve incorporated inside the master cyl that holds a certain amout of pressure on the brake lines,,,,, the reason being is for quick action of the brakes when you apply the brake lever, so it wouldnt have to wait to build up pressure!
duh! you have to back bleed the brakes, the same way its done at the factory when they assembled your bike when it was new!
ok, ok, you don't want to spend $80 on a back bleeder,,,, I understand, but what works just as good and in my opinion works better is buy a cheap $3 plastic oil can one with the trigger and the metal tube that sticks out, then get a 1 foot piece of vacuum line, or windshield washer hose,,, I don't know 3/16? it streches and clamp one end to the oil can with a hose clamp, then fill up the oil can with brake fluid, and place the other end of the hose to the open bleeder screw of the caliper and just pump the oil can and amazed you'll see the master cyl fill up,, wow!, then close the bleeder screw and instant brakes and no mess of brake fluid on the floor!
what??? a professional motorcycle mechanic didn't know that? ha ha ha ha ha ha really??? ha ha ha ha ha pointing my fingers at him,,, ha ha ha ha ha !
2009 Yamaha TMAX
2008 Suzuki King Quad 750AXI
fireguzzi
Real Name: Trevor
#10 Unread post by fireguzzi »
That procedure has nothing to do with why he is losing pressure a year after getting his brake line replaced.
