Hi Riders,
I have been riding bikes for over 20 years, I have recently come across an 82 Honda CB900C, I am in the process of making a bobber. I am having Clutch problems, the Push Rod will not move. I can tell that someone has tried to do some work on it because the screws were loose on the case and the seal was new. When I pull in the clutch it does not move the push rod. I have checked the Cable and that is not the issue. Does anyone have any ideas?
Thanks
Rford
Push rod not moving
- Real Name: Ryan
Re: Push rod not moving
Chances are that the pushrod itself is seized into the housing.
I don't know that specific bike, but if you can, get on the back side of it and use some compressed air/hydraulic pressure to break it loose.
- Real Name: rford
- Years Riding: 27
- My Motorcycle: 1982 honda cb900 (bobber)
I will try that, and let you know how it goes, It will be a few days before I can work on the bike again.
Thanks.
Thanks.
- Real Name: rford
- Years Riding: 27
The Clutch problem is solved, thats for all the help, you guys are great, on to the next step, fixing the seal on my front folks.
- Real Name: rford
- Years Riding: 27
Forks,
sorry,
lol
sorry,
lol
...and Reford, can you share how you solved/fixed it for others here?
- Real Name: Ryan
That'd be very helpful! And no problem.
