2013 BMW R1200GS: Voted Cool
Posted: Sat Nov 24, 2012 11:58 am
2013 BMW R1200GS on the Total Motorcycle Cool Wall
More photos and information: http://www.totalmotorcycle.com/motorcyc ... 1200GS.htm
2013 BMW R1200GS
One R 1200 GS. One Mission – The best GS of all times.
The BMW R 1200 GS – the icon of all travel enduros. For 32 years “the GS” has been defining its segment and has proven to be the trusty companion on any motorcycle adventure. BMW Motorrad is now embarking on a new chapter of its success story and is yet again perfecting the iconic R 1200 GS.
One R 1200 GS. One Feeling – Power in every situation.
Powerful, refined, and high revving. The R 1200 GS is powered by a new opposed twin engine design delivering 125 hp. Based on a new concept of combined air and liquid cooling and vertical flows through the cylinders, the engine operates efficiently, reliably, and with high torques at all times. Further improvements like the new wet clutch with antihopping feature, the electromotive throttle actuator E-Gas, and the optional “riding modes” make the opposed twin engine the perfect drive solution at the heart of the new R 1200 GS.
One R 1200 GS. One Emotion – Supreme control
The new R 1200 GS is ready for any terrain, thanks to the greater rigidity of its main frame and its enhanced Paralever and Telelever for even greater enduro steering accuracy. The optional Dynamic ESA configures the suspension automatically to the terrain and load conditions. The GS provides even more functions with the optional “riding modes”, a set of four different configurations that can be selected at the push of a button.
One R 1200 GS. One Impression – Strong individuality.
At first glance, the “new one” too is a genuine GS: robust, dynamic, and full of character. New body panels with a perfect finish underscore its high quality character. The new cooling concept was integrated seamlessly into the distinctive design, and the visual emphasis moved to the front. The new R 1200 GS now gives the impression of more balance and power. Thanks to its extensive range of options, the R 1200 GS is absolutely unique. With an innovative, unique LED headlamp, cross spoke wheels, and a wide choice of options and packages, everyone can convert this enduro into “his” or "her" GS.
One World. One R 1200 GS – The tour of your life.
At the launch of the new R 1200 GS, BMW Motorrad will be setting a unique test ride in motion. In the “One World. One R 1200 GS.” event, BMW Motorrad will be sending five enduro adventurers on the redefined icon R 1200 GS on five tours all around the world. The first of its kind in the world, this project will be putting “the new one” to a gruelling test – and, with a little luck, give you too the opportunity for the tour of your life.
2013 BMW R1200GS - USA Specifications/Technical Details
US MSRP Price: See dealer for Pricing.
Engine
Capacity cc 1,170
Bore/stroke mm 101/73
Output kW/bhp 92/125 at engine speed rpm 7700
Torque Nm 125 at engine speed rpm 6500
Type air/water-cooled 2-cylinderboxer engine
No. of cylinders 2
Compression/fuel 12.5:1 / Premium unleaded (95 RON)
Valve actuation DOHC
Valves per cylinder 4
Ø Intake/outlet mm 40/34
Ø Throttle valve mm 52
Carburetion BMS-X
Emission control Closed-loop 3-way catalytic converter
Electrical system
Alternator W 620
Battery V/Ah 12/12 maintenance-free
Headlight W H7 / LED (SA)
Starter kW 0.9
Power transmission - gearbox
Clutch Anti-hopping wet clutch
Gearbox Constant mesh 6-speed gearbox
Primary ratio 1.65
Transmission ratios I 2.438
II 1.714
III 1.296
IV 1.059
V 0.943
VI 0.848
Rear wheel drive cardan shaft
Transmission ratio 2.91
Chassis
Frame construction type Tubular steel bridge frame, engine self-supporting
Suspension, front BMW Telelever
Suspension, rear BMW EVO Paralever
Spring travel, front/rear mm 190/200
Wheel castor mm 99.6
Wheelbase mm 1507
Steering head angle ° 64.5
Brakes front Hydraulically actuated twin disc brake, Ø 305 mm
rear Single-disc brake Ø 276 mm
BMW Motorrad Integral ABS (standard, part intergal, disengageable)
2013 BMW R1200GS
Engine
Capacity cc 1,170
No. of cylinders 2
Carburetion BMS-X
Electrical system
Alternator W 620
Starter kW 0.9
Primary ratio 1.65
II 1.714
III 1.296
IV 1.059
V 0.943
VI 0.848
Chassis
Wheelbase mm 1507
