how do you remove a link from a chain?
goodcruisin
#1 Unread post by goodcruisin »
my chains stretched to the point where i dont have any more adjustment on my axel, can i pull a link out, or do i need to brake down and buy a chian?
or mayby a bigger sprocket.
so many roads............ so little time!
gonna ride em all in washington....
then find some more
Gadjet
Real Name: Owen Clark
Years Riding: 19
#2 Unread post by Gadjet »
Time for a new chain, as well as sprockets if they are worn.
It is always best to replace sprockets and chain at the same time, otherwise the new parts will wear out faster, leading to earlier replacement intervals.
1983 Suzuki GS650GL (sold)
2005 Kawasaki KLR 650 (sold)
2020 KTM 200 Duke
IBA#20953
IG: @greenmanwc
TechTMW
#3 Unread post by TechTMW »
You need a new chain and sprocket.
The chain has stretched out -between each link- therefore the spaces between links no longer corresponds perfectly with the spaces on the sprockets. This has led to wear on the sprocket - so once you buy a new chain, it will not fit properly on the old sprocket.
Hence new chain and sprocket - probably a good idea to fit a new front sprocket as well.
To break a chain (and usually to fit a chain) you will need one of these
http://www.cycleshopusa.com/p1752.htm
goodcruisin
#4 Unread post by goodcruisin »
suppose your right, the sprocket also looks a little tired.
thanks guys :? :
then find some more
