More photos and information: http://www.totalmotorcycle.com/motorcyc ... ersary.htm
2013 Ducati Monster 696 20th Anniversary
Everyday usability
With its thin waistline and wide handlebars, the Monster 696 provides unrivalled ergonomics, striking a carefully designed balance between performance and everyday usability that will appeal to a wide range of riders. Sport-derived chassis technology and the proven power and flexibility of the legendary Ducati L-Twin engine, make the Monster 696 as comfortable in city traffic as on the open road. Enhancing the "less-ismore" philosophy that has made the Monster a global legend, the Monster 696 continues to redefine expectations. Every finely engineered element of the chassis and engine is on display, allowing its true beauty to be showcased for all to see.
Riding the 696
The riding position of the Monster 696 has been specifically designed to put the rider firmly in control. With its low 770mm (30.3in) seat height, easy-to-reach handlebars and user-friendly 4-point adjustable levers, every rider will find it easy to master.
The beautifully sculpted fuel tank cover allows maximum comfort and control and the narrowing of the "waist" area of the 696 has the same effect as lowering the seat height, making it easier to get both feet flat on the ground. Careful attention to every detail has led to a substantial weight saving, making the Monster 696 the lightest in its class at an impressive 161kg (355lb) (dry weight).
Passenger comfort and safety arealso carefully considered, with neat, under-seat grab handles moulded into the seat unit maximising pillion security without detracting from the legendary Monster 696 styling, or external grab-handles available as an accessory from Ducati Performance.
696 power trip
The 696 engine produces 80hp (59kW) and 50.6lb-ft (7kgm) of torque ensuring a smooth and powerful delivery for a relaxed and enjoyable ride as well competitive and owner-friendly service intervals of 7,500 miles (12,000 kilometres).
The highly efficient, lightweight engine uses a bore and stroke of 88x57.2mm and, like the 796, features an advanced APTC 'wet' clutch. With a 'slipper' type action that prevents destabilising of the rear-end under aggressive down-shifting, the APTC clutch also gives the extra benefit of a super-light feel at the lever, a great benefit in stop-start city traffic. The oil-bath clutch represents a power-enhancing weight reduction over the 'dry' system as well as having a considerably quieter operation.
Providing a deep and rich exhaust tone within current regulations is no mean feat, but the Monster 696 definitely provides Ducati's famous L-Twin sound. Its bold, high-level twin mufflers not only make a striking style statement, but also provide a healthy increase in power and torque and ideal positioning for two lambda exhaust gas sensors, crucial for the optimisation of fuelling and emissions.
696 chassis
Outstanding handling and control is provided by 43mm Kayaba forks offering 120mm (4.7in) of finely controlled travel. At the rear, a progressive Sachs monoshock unit provides adjustability in both spring preload and damping.
Lightweight 3-spoke aluminium alloy wheels increase agility and reduce rider effort and use 120/60ZR front and 160/60ZR rear Pirelli Angel ST tyres. The end result provides a light, predictable and confidenceinspiring "feel" with outstanding stability at a wide range of speeds.
The Brembo brakes deliver exceptional braking power front and rear, enhancing rider safety. 320mm front floating discs are gripped by 4-piston, radially mounted callipers, while a 245mm rear disc works in combination with a twin-piston calliper. This powerful braking set-up offers unrivalled feel and feedback that inspires confidence across a broader spectrum of riding abilities. Riders looking for even more security will benefit from the optional ABS system.
Every carefully selected component of the Monster 696 has a net benefit to the overall weight of the machine and not only enhances manoeuvrability and ease of use, but also contributes directly to increased performance of both braking and acceleration.
Celebrating 20 years of iconic Monster style
The Monster family reaches a milestone 20 years of production in 2013 and Ducati celebrates the iconic naked motorcycle with special 20th Anniversary editions of its latest 696, 796 and 1100EVO models.
Standing proudly alongside the exclusive Monster Diesel, this bold range of lifestyle motorcycles is engineered with high attention to user-friendly and safety-conscious detail ensuring the Monster's cult status remains as authentic as ever.
With stylish Trellis frames, excellent chassis components and torque-laden, Desmodromic engines giving that unmistakable sound and character, the entry-level 696 and premium mid-range 796 Monsters provide a desirable way to enter the world of Ducati.
2013 Ducati Monster 696 20th Anniversary - USA Specifications/Technical Details
MSRP Price: See dealer for pricing
Engine
TYPE
L-Twin cylinder, 2 valve per cylinder Desmodromic, air cooled
DISPLACEMENT
696cc
BORE X STROKE
88 x 57.2mm
COMPRESSION RATIO
10.7:1
POWER
58.8kW - 80hp @ 9000rpm
TORQUE
7.0kgm - 50.6lb-ft @ 7750rpm
FUEL INJECTION
Siemens electronic fuel injection, 45mm throttle body
EXHAUST
2 aluminum mufflers
Transmission
GEARBOX
6 speed
PRIMARY DRIVE
Straight cut gears; Ratio 1.85:1
RATIO
1st 32/13, 2nd 30/18, 3rd 28/21, 4th 26/23, 5th 22/22, 6th 24/26
FINAL DRIVE
Chain; Front sprocket 15; Rear sprocket 45
CLUTCH
APTC wet multiplate with hydraulic control
Chassis
FRAME
Tubular steel Trellis frame
FRONT SUSPENSION
Marzocchi 43mm upside-down forks
FRONT WHEEL
3-spoke light alloy 3.50 x 17
FRONT TYRE
Pirelli Angel ST 120/60 17"
REAR SUSPENSION
Progressive linkage with preload and rebound Sachs adjustable monoshock
REAR WHEEL
3-spoke light alloy 4.50 x 17
REAR TYRE
Pirelli Angel ST 160/60 17"
FRONT WHEEL TRAVEL
120mm (4.7in)
REAR WHEEL TRAVEL
148mm (5.8in)
FRONT BRAKE
2 x 320mm discs, 4-piston radial caliper
REAR BRAKE
245mm disc, 2-piston caliper
INSTRUMENTATION
Digital unit displaying: Speedometer, rev counter, clock, scheduled maintenance warning, oil temperature, trip fuel, air temperature, lap time, warning light for low oil pressure, fuel level, fuel reserve, neutral, turn signals, overrev, immobilizer. Ready for DDA system
Dimensions and weight
DRY WEIGHT
161kg (355lb) / 163kg (359lb) ABS version
WET WEIGHT
185Kg (407lb)
ABS WET WEIGHT
186kg (410,1lb)
SEAT HEIGHT
770mm (30.3in)
WHEELBASE
1450mm (57.1in)
RAKE
24°
TRAIL
87mm (3,42 in)
FUEL TANK CAPACITY
15l - 3.8 gallon (US) 13.5l - 3.6 gallon (US) ABS version
VERSIONS
Dual seat
Warranty
WARRANTY
2 years unlimited mileage
VALVE CLEARANCE CHECK
7.500m
Emissions and Consumption
STANDARD
follows the US Federal Regulation
