Newbie mistakes and mysteries
- Real Name: David
- Years Riding: 10
- My Motorcycle: DNA
Bought a 2005 Honda Shadow VLX600 with 2717 miles on it. My first bike since returning to riding after quite a while.
Got it home and, given the weather here in Colorado, was only able to ride it a short distance. Made the rookie mistake of starting it and letting it run for a couple of minutes with the gas valve on reserve. It soon sputtered to a stop.
Haven't been able to re-start it since. Seemed like I was running the battery down trying to re-start it. Only had a charger meant for my truck so I waited until I could get a 12V charger.
However the last few attempts to start it before the battery ran down (I think it ran down) resulted in the engine not cranking over 'mechanically' if you know what I mean. All I was hearing was a buzzing sound like a bad game-show buzzer. I have filled it with gas and kept some heat in the garage since as well.
Could the starter have gone bad?
The trickle charger is on it now and I'll see what happens when the battery is charged.
I have a steep driveway and a down-hill street but I don't think I have enough experience to 'bump' start it. And it's a long uphill push back if it doesn't start.
Any opinions?
On another note, the owner's manual has a whole chapter on the maintenance of the 'chain drive'. This bike has a belt drive. I crossed checked the VIN and it shows it as a 2005 Honda Shadow VLX600 for sure, but could this mean someone swapped it out for a belt drive? Or...?
Thanks
Any opinions?
Thanks
- Real Name: Ryan
Re: Newbie mistakes and mysteries
Either outta gas or the float valves on the carbs are bad and caused it to flood/foul out the plugs.
Where in CO are ya? I'm in the Springs and can stop by soon if you need. (Plenty of experience with bump starting, so if that's all it needs, not a problem.)
- gsJack
- Legendary 500
- Years Riding: 30
- My Motorcycle: 02 GS500
I'd jump start it from a non running car to get it started and ride it to charge it. VLX600 never came with a belt drive, someone must have converted it.
- JackoftheGreen
- Real Name: Eric
- Years Riding: 12
- Contact:
I think you'll be fine once the battery's charged. Sit it out for a few hours and let the trickle charger do it's thing, reinstall your battery and check the fuel petcock, and I'll wager it'll turn right over for you.
- Jack of the Green
Some Awesome Threads:
What Did You Do Today?
Social Media:
TMW on DailyMotion!
The TMW YouTube Channel!
TMW on Facebook!
Patreon
Social Media:
TMW on DailyMotion!
TMW on Facebook!
Patreon
- Tricycle Squid
- Real Name: faari
- Years Riding: 2
- My Motorcycle: honda
The bike has 11.00 HP and 10.84 NM torque at 9000 maximum RPM rate. It has 6.43 liters fuel capacity and it is kick starter.
faari
- Veteran
- Real Name: Sam Edward
- Years Riding: 2
- My Motorcycle: 2012 BMW F650
tried to show a guy who would like normally fix the bikes?
Considering the original poster made his post almost a year ago....it's probably fixed by now.
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
- Veteran
- Years Riding: 2
Sorry my wrong I did see the date at firstblues2cruise wrote:Considering the original poster made his post almost a year ago....it's probably fixed by now.
![Sad :(](./images/smilies/icon_sad.gif)
- Veteran
- Real Name: Art
- Years Riding: 50
- My Motorcycle: FXDBI
Ya never know.
