Back Brake Stinking
Fwoodard64
Real Name: Frank Woodard
My Motorcycle: 81/Honda/Goldwing
Back Brake Stinking
#1 Unread post by Fwoodard64 »
I have a 81 Honda GL1100 GoldWing Interstate and the back brake keeps sticking. The only way I can get the bike moving is power through first and second gear. After a short time of rolling the brake will give a free itself. Why is this happening and what can I do to prevent it? Thanks for any comments.
pchast
Re: Back Brake Stinking
#2 Unread post by pchast »
First we really need to know when its sticking. When you first start out or after things heat up?
Fwoodard64
#3 Unread post by Fwoodard64 »
Any time i push on the back brake lever. Bike can be cold or warm, motor on or off.
NorthernPete
Years Riding: 11
#4 Unread post by NorthernPete »
Seized caliper?
2009 GS500F
Fwoodard64
#5 Unread post by Fwoodard64 »
Thanks for the help. that should be an easy enough fix. Its a little hard to stop a Gold Wing with just the front brake.
#6 Unread post by Wrider »
You shouldn't have any trouble stopping the bike with just the front. You ought to rebuild all three calipers if the rear is sticking and the fronts aren't working well.
Fwoodard64
#7 Unread post by Fwoodard64 »
Thanks i planned on doing both. We have a lot of salt and grim still on the roads from the winter so back brake helps control through braking. Thanks for all the help.
Fwoodard64
#8 Unread post by Fwoodard64 »
I am sure i will have more quesgions in the future. This site will be a big help.
