2013 Triumph Thunderbird: Voted - 64.4%
Posted: Fri Apr 19, 2013 5:55 am
2013 Triumph Thunderbird on the Total Motorcycle Cool Wall
More photos and information: http://www.totalmotorcycle.com/motorcyc ... erbird.htm
Go on a legend reborn.
Strong, muscular lines. Impeccable manners. Outstanding engineering. A tour de force. Voted 'Cruiser of the Year' by Cycle World magazine in the USA, Thunderbird rewrites the rules and brings Triumph's reputation for handling and engineering excellence to the cruiser market. Personalisation? No problem, with great paint schemes and over 100 accessories. It's what cruiser riders have been waiting for.
The critically acclaimed new Thunderbird is a revelation. The bike that cruiser riders have been waiting for. But its turning heads among other types of rider too. Why? Because it delivers - on looks, on power, on handling, on comfort, on everything.
On the road or on the spec sheet, Thunderbird leads the way. Sit astride the well appointed low seat and enjoy the high quality chrome that dominates the design.
The tank mounted speedo includes a small built in tacho and on-board computer which includes clock, two trip meters and a fuel gauge. Low maintenance belt drive, Triumph’s first in the modern era, delivers the torque smoothly and cleanly, while the cycle parts ooze class and quality. Anti-lock brakes are an option for the Thunderbird, offering extra reassurance on all road conditions.
But riding a cruiser is all about individuality and with over 100 accessories you can personalise your Thunderbird and find your own unique look. From stripped down street rod to a soft bagged tourer, the Thunderbird delivers with style and charisma.
2013 Triumph Thunderbird - USA Specifications/Technical Details
US MSRP Price: MSRP $13,499(Single Color ABS)$13,799(Two-tone ABS)$13,999(Haze)
Canada MSRP Price: On The Road $14,499(Phantom Black)$15,499(two-tone)$15,799(Marble Haze)
Engine and Transmission
Type Liquid-cooled, DOHC, Parallel-twin, 270º firing interval
Capacity 1597cc
Bore/Stroke 103.8 x 94.3mm
Fuel System Multipoint sequential electronic fuel injection, progressive linkage on throttle
Exhaust Chromed twin-skin stainless steel 2 into 1 into 2, tandem large-volume catalysts in centralized catbox, chrome-plated exhaust
Final Drive Toothed Belt
Clutch Wet, multi-plate
Gearbox 6-speed, helical type 2nd - 6th
Oil Capacity 4.2 liters (1.1 US gals)
Chassis, Running Gear and Displays
Frame Tubular Steel, twin spine
Swingarm Twin-sided, steel
Wheel Front Cast aluminum alloy 5-spoke 19 x 3.5 in
Rear Cast aluminum alloy 5-spoke 17 x 6 in
Tire Front 120/70 R19
Rear 200/50 R17
Suspension Front
Showa 47mm forks. 120mm travel
Rear
Showa chromed spring twin shocks with 5 position adjustable preload. 95mm rear wheel travel
Brakes Front
Twin 310mm floating discs. Nissin 4-piston fixed calipers, ABS
Rear
Single 310mm disc. Brembo 2-piston floating caliper, ABS
Instrument Display/Functions
Analogue speedometer featuring integrated rev counter, scroll button on handlebars, LCD trip computer, fuel gauge and clock
Dimensions and Capacities
Length 2340 mm (92.1 in)
Width (handlebars) 880 mm (34.6 in)
Height without mirrors 1120 mm (44.1 in)
Seat Height 700 mm (27.5 in)
Wheelbase 1615 mm (63.5 in)
Rake/Trail 32º/151mm
Fuel Tank Capacity / Efficiency 22 liters (5.8 US gals)
Wet Weight (ready to ride) 339 kg (746 lbs)
Performance (measured at crankshaft to 95/1/EC)
Maximum Power 86PS / 85bhp / 63 kW @ 4850rpm
Maximum Torque 146Nm / 108 ft.lbs @ 2750rpm
Fuel Efficiency 38 MPG City / 56 MPG Highway *Estimated from fuel economy tests on a sample motorcycle conducted under ideal laboratory conditions. Actual mileage may vary based upon personal riding habits, weather, vehicle condition, and other factors.
Capacity 1597cc
Rear 200/50 R17
Suspension Front
Rear
Brakes Front
Rear
