2003 Kawasaki ZRX 1200R Starter not turning over
terminator
Real Name: Tom
My Motorcycle: 2003 Kawasaki zrx 1200R
#1 Unread post by terminator »
Battery is good, fuses good. Could it be the starter relay? Is there a way to check it? The bike has 9000 miles on it. :frusty:
Re: 2003 Kawasaki ZRX 1200R Starter not turning over
#2 Unread post by Johnj »
Hello Tom, and welcome to the forum. Can I ask how you know the battery and fuse's are good. The way I test a battery is (with a voltmeter across the battery) try to start the bike. Does the voltage stay above 10 volts. The starter relay should have four wires on it, two big wires and two smaller wires. The smaller wires are the starter switch. Momentarily short the two smaller wires and the starter should crank. If it does your problem is elsewhere. If it doesn't crank the starter (use a large screwdriver) momentarily short the big wires. If it cranks now you have a bad starter relay. Good luck.
