Vibrations around 4500 RPM
beerbaron
#1 Unread post by beerbaron »
Hi, my bike makes some vibration when the engine revs around 4500 RPM. It's a Yamaha FZ-600 1988. Someone else had such bike or such problem ?
I was thinking of putting some rubber under de clip on to help reduce it. Any more suggestions?
Thanks
BeerBaron
kar_the_terrible
#2 Unread post by kar_the_terrible »
are the engine mounts worn?? maybe you need to replace the boots/bushings on the mounts.
'78 Yamaha XS400
'86 Yamaha Radian
stormme66
#3 Unread post by stormme66 »
Kar is right, all engines have a period of resonance, and this is likely to be the cause of the vibrations, especially as you say that they occur within a specific rev range.
Check your mounts, and check the bolts are all tight too. Also make sure the exhaust is not rubbing on the frame or anything.
S
that's my 2 cents worth.....
NORTY
Real Name: Occupant
My Motorcycle: Harley & Trumpet
#4 Unread post by NORTY »
Does the Fizzer have a "counter-balancer?" If so, then adjust it to factory specs. There is some handlebar weights that can help. About 4000-4500 is where 4 cylinder engines make the most "buzziest" vibration.
MSF RiderCoach
beerbaron
#5 Unread post by beerbaron »
Thanks guys, I'll look up for that.
BeerBaron
