clutch
suprkaw
Real Name: david burcham
My Motorcycle: 2000 kawasaki
clutch
#1 Unread post by suprkaw »
i have a 2000 kawasaki vulcan 1500 that runs great until its been run for 40 50 miles snd then i cant idle at red lights because it there is no resistence at all on the clutch lever, could somebody please tell me how to correct this problem as i have quit riding until it is corrected.
BRUMBEAR
Real Name: Dave
Years Riding: 40
Re: clutch
#2 Unread post by BRUMBEAR »
check your resevior if you have a slave cyl or hyd clutch it may be empty
there aint nothin like it
Re: clutch
#3 Unread post by Wrider »
Agreed. Sounds like your clutch needs to be bled.
GS_in_CO
Real Name: Ron
Re: clutch
#4 Unread post by GS_in_CO »
If the clutch operates fine for the first 50 miles that suggests to me it's not dry.
Might have air in the system that expands when it gets hot?
Or the slave cylinder gets hot, expands and the piston no longer seals.
I dunno.
(I don't like hydraulic clutches for the long term.)
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
BRUMBEAR
Real Name: Dave
Years Riding: 40
Re: clutch
#5 Unread post by BRUMBEAR »
Open the reservoir and have a look there boyO every journey starts with the first step :D Seriously though the fliud may boil when it gets hot if it's low and you start to loose consistency. Either way the first step is the same.
storysunfolding
Years Riding: 22
Re: clutch
#6 Unread post by storysunfolding »
GS_in_CO wrote:If the clutch operates fine for the first 50 miles that suggests to me it's not dry.
Air or water. Remember the fluid is hydroscopic. Flush the lines with new fluid and I bet it goes away. I bet it's a nasty color right now. Remember your fluid should be like your urine- slightly yellow but mostly clear.
My Blog
Grasp life by the handlebars
BRUMBEAR
Real Name: Dave
Years Riding: 40
Re: clutch
#7 Unread post by BRUMBEAR »
Well said I replace my fluid, Clutch and brake every year even though I use Dot5.
