2001 suzuki marauder vz800
moomoodavis
My Motorcycle: 2001 suzuki marauder vz800
#1 Unread post by moomoodavis »
Hello all,
When I start my marauder, the exhaust coming out of the back end never heats up, any ideas? I tried swapping spark plugs but that does not seem to fix it.
Thank you for your time.
Re: 2001 suzuki marauder vz800
#2 Unread post by Johnj »
Hello there moomoo, and welcome to the forum. What I get from your post is that you don't think your exhaust gasses are getting hot enough. Other than that how does your bike run?
moomoodavis
#3 Unread post by moomoodavis »
It isn't running well, I don't think it is pulling air in the back end. When I shoot a little starter fluid into the air filter the engine does not rev up.
#4 Unread post by Johnj »
Air comes in through the carburetor, mixes with gasoline, then goes though the combustion chamber and exits through the exhaust. Have you tried running some Seafoam® or other carb cleaner in you gas?
