Suzuki GS550ES all kinds of issues
Posted: Sun Sep 01, 2013 8:13 pm
Hi everyone
I picked up a GS550ES a month ago and have been trying to get it up and running since. It's been problematic, but I bought it knowing that it would be a bit of a project. It's also my first bike so I am itching to ride.
Anyway, when I got it, it ran - but if I gave it throttle it would die. So I pulled the carbs, cleaned them out well, and after issues with the sticking float and having it pour gas out of the airbox, three days ago I finally got it going. Put about 150 miles on it, ran really smooth and was a ton of fun.
Today it started sputtering and dying on me, and from trying to start it the battery died. So I had my buddy push start it and that worked, but it kept dying. Realized (or I thought?) it was low on gas, and my petcock does not work right so I can't put it on reserve, so I filled it up and that fixed that issue. Rode it for about 30 miles and it died on my again, at a stop light when I was trying to get going. Got it started again with a push, and it died while slowing down but not stopped a few miles later. Then it ran fine.
Got it home eventually, thankfully and surprisingly, and there is gas coming from the carb around the float bowl seals. Seems straight forward, needs new seals. Could that be the issue here? Some kind of vacuum issue from a float gasket?
TLDR; bike dies when given gas, sometimes, but then it will run perfectly fine. And then the same issue.
Any ideas?
Any ideas?
