Difference Between Chain Types
WyckedZX10R
#1 Unread post by WyckedZX10R »
OK, I've been riding two wheeled motorized vehicles for about thirty years so I consider myself fairly wise in the ways of the motorcycle...but something I didn't know that I didn't know until today is this...
I'm shopping for a new chain for my bike and I don't know what the differences between a racing and a non-racing chain are.
Can someone enlighten me?
Thanks,
Doc
kar_the_terrible
#2 Unread post by kar_the_terrible »
www.dansmc.com has some info about racing chains etc. you can check it out if you want to read it in detail.
I think the difference is racing chains are a lot lighter, hence wear faster and need more frequent replacement.
'78 Yamaha XS400
'86 Yamaha Radian
mikaloyd
#3 Unread post by mikaloyd »
First off what Im going to write has to do only with O-Ring type chains used on street bikes and roadracing bikes. Dirtbikes and dragbikes have gone different directions with "racing chain"
The short answer to "What's racing chain?" is mostly advertising shenanigans. From the major manufacturers a "racing chain" is a somewhat stronger (but not for sure better for your use) chain than their standard chain of that size(almost certainly with sideplates plated a golden color so folks can tell you paid extra) Racing chain might or might not last longer than the chain which came with your bike. It wont even last as long btw unless you also replace your sprockets and ensure that they are properly aligned. From the less scrupulous manufacturers the term "racing chain" means nothing whatsoever. Except maybe gold sideplates and higher cost.
The long answer takes awhile
WyckedZX10R
#4 Unread post by WyckedZX10R »
The Cliff's Notes version is fine. Thanks tons.
Doc
Itzamna
#5 Unread post by Itzamna »
The lighter weight is really the big difference to me. Usually replace with lighter weight sprockets as well, dropping some overall weight from the bike. I've heard from many people that they will wear real quick if you're real hard on the throttle. Especially the lighter sprockets.
Brian
'03 Suzuki SV1000
