2014 Ducati Monster 1200 - Coolness Factor = 86.2%
Your Coolness Factor of the 2014 Ducati Monster 1200 is:
57
74%
19
25%
1
1%
0
No votes
Total votes: 77
2014 Ducati Monster 1200 on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... r-1200.htm
2014 Ducati Monster 1200 on Totalmotorcycle.com
Monster Instinct...
The performance and fluidity of the new Testastretta 11° DS engine, the versatility of the three Riding Modes, the comfort of the adjustable seat and passenger handles make the Monster 1200 a bike that is capable of adapting to any occasion, so that you can follow your instincts in every situation. The unmistakeable Monster design is truly iconic and means there is no limit to your enjoyment.
Twenty-one years on from the Monster’s first unveiling, Ducati now introduce the iconic model’s latest generation with the 2014 Monster 1200 and 1200 S powered by the formidable, Superbike-derived 1198 Testastretta 11° DS engine. The brand new flagship of the family presents an entirely new chassis and muscular styling designed with premium components fully integrated with Ducati’s latest technologies.
Evoking the exciting memories of past models such as the powerhouse S4R and S4RS, the 2014 Monster 1200 also boasts an exclusive S model with 145hp and a ride-enhancing 92ft-lb of high-accelerating torque, wrapped beautifully in a spec-impressive chassis that tips the scales at 182kg (401lb) dry weight.
High-spec brakes, suspension, single-sided swingarm and lightweight wheels combine with Ducati’s best-yet ergonomics to offer the Italian manufacturer’s most attractive Monster ever. Super comfortable and introducing an innovative adjustable seat height, the model also combines 8-level traction control, 3-level ABS and 3-level Ride-by-Wire into Ducati’s user-friendly, press-button Riding Modes.
The 2014 Monster 1200 and Monster 1200 S use next generation technologies to create an enhanced rider/motorcycle relationship, delivering a high-adrenaline experience while constantly reassuring with the feeling of complete control and ergonomic integration.
2014 Ducati Monster 1200 - Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $13,495 USD
Canada MSRP Price: $14,595 CDN
British MSRP Price: £ 10,695 GBP
Engine Type
Testastretta 11°, L-Twin cylinder, 4 valve per cylinder, Desmodromic, liquid cooled
Displacement
1198.4cc
Bore x Stroke
106 x 67.9mm
Compression ratio
12.5:1
Power
100.7 kW (135 hp) @ 8,750 rpm
Torque (Totalmotorcycle.com)
118 Nm (87 lb-ft) @ 7,250 rpm
Technical data referring to power and torque was measured on an engine test stand at Ducati.
Fuel injection
Electronic fuel injection system, 53mm throttle bodies with full Ride by Wire
Exhaust
Lightweight 2-1-2 system with catalytic converter and two lambda probes. Twin aluminium mufflers
Transmission
Gearbox
6 speed
Primary drive
Straight cut gears, ratio 1.84:1
Ratio
1=37/15 2=30/17 3=27/20 4=24/22 5=23/24 6=22/25
Final drive
Front sprocket 15; Rear sprocket 41
Clutch
Light action, wet, multiplate clutch with hydraulic control. Self-servo action on drive, slipper action on over-run. (Totalmotorcycle.com)
Chassis
Frame
Tubular steel Trellis frame attached to the cylinders head
Front suspension
43mm fully adjustable usd forks
Front wheel
10-spoke in light alloy 3.50 x 17
Front Tyre
120/70 ZR 17 Pirelli Diablo Rosso II
Rear suspension (Totalmotorcycle.com)
Progressive linkage with fully adjustable monoshock. Aluminium single-sided swingarm
Rear wheel
10-spoke in light alloy 6.00 x 17
Rear tyre
190/55 ZR17 Pirelli Diablo Rosso II
Front wheel travel
130mm (5.1in)
Rear wheel travel
152mm (5.9in)
Front brake
2 x 320mm semi-floating discs, radially mounted Monobloc Brembo M4-32 callipers, 4-pistons, radial pump with ABS as standard
Rear brake
245mm disc, 2-piston floating calliper with ABS as standard equipment
Instrumentation
Colour TFT display
Dimensions and weight
Dry weight
182kg (401lb)
Weight data refers to the dry weight of the motorcycle without battery, lubricants and coolants for liquid-cooled models.
Wet weight (KERB)
209Kg (461lb)
Kerb weights indicate total bike weight with all operating consumable liquids and a fuel tank filled to 90% of capacity (as per EC standard 93/93). (Totalmotorcycle.com)
Seat height
Adjustable 785 - 810 mm (30.9 - 31.9)
Wheelbase
1511mm (59.5in)
Rake
24,3°
Trail
93.2mm (3.7in)
Fuel tank capacity
17.5l - (4.6 US gal)
Number of seats
Dual seat
Equipments
Standard Equipment (Totalmotorcycle.com)
Riding modes,Power modes, DSP Ducati Safety Pack (ABS + DTC), RbW, passanger handles and seat cover, ready for anti-theft system and DDA
Warranty
Warranty
24 months unlimited mileage
Maintenance service intervals
9,000m/12 Months
Valve clearance check
30.000km (18,000m)
Re: This week: 2014 Ducati Monster 1200: Vote Today
Just released and brand new from Ducati for 2014... a new breed of Monster.
See all the new 2014 Ducati Motorcycles right here on Total Motorcycle: http://www.totalmotorcycle.com/motorcyc ... Ducati.htm
The front half looks good. The rear fender looks stupid. And the comment in the text about adjustable passenger handles...hahahahaha....I can't imagine being a passenger on a postage stamp sized seat.
BRUMBEAR
Real Name: Dave
Years Riding: 40
#4 Unread post by BRUMBEAR »
GAWD that thing is SEXY and even though they stole the XB Buell exhaust headers I still LOVE it!!!!!!!!!
there aint nothin like it
Grey Thumper
Real Name: Dino
#5 Unread post by Grey Thumper »
So relieved Ducati got rid of those "vents" (for the airbox?) on the tank. Much sleeker. Engine plumbing is a bit messy (air-cooled Monsters are much cleaner, but what do you expect?). Still awesome, and arguably still the best looking liter-class naked bike.
JackoftheGreen
Real Name: Eric
#6 Unread post by JackoftheGreen »
I'd like to give this an Awesome, because it sure looks like an Awesome machine, but I'm having a hard time with that. I can't imagine the average rider would ever get more than 60% out of this bike, maybe 70% if they were young and in great health. That being the case, this bike is 30-40% bragging rights, and that's a hefty mark-up.
In addition, damn those folks at EBR, but now when I see a sport bike with plain central brake rotors and matching rims, I assume the engineers left some performance on the table. That's the danger of asking questions I guess. (-: The single-sided swingarm sure is cool though.
So here's my Cool vote. (-:
ceemes
Real Name: a big secret
#7 Unread post by ceemes »
oooooo, now that is one tasty, meaty sexy looking nekkid bike....I even like the rear fender....lets face it, the rear fender of bikes like this are generally so butt ugly, that riders opt to spend even more money on getting after market replacement kits, I figure Ducati is just being pro-active and getting rid of them in the first place, thus saving its customers a bit of coin.
ZRex
Real Name: Ben
#8 Unread post by ZRex »
I have always loved Monsters, that is actually how I found out about TMW. A few years ago(2007ish) I was looking for a picture of a Ducati Monster 1000 and that is how I found Total Motorcycle.com. I really like this bike, actually I really want this bike, so I definitely have to vote Awesome.
Mithrandir
Real Name: Anthony
My Motorcycle: None
#9 Unread post by Mithrandir »
The MC looks great but I would not like to try fitting on the passenger seat. (As blues2cruise noted it is about the size of a stamp.)
It is more MC than I could (currently) handle or want, but it would probably be fun on the PCH and the interstate highways.
I voted: A very solid Cool.
If it just wasn't for that low, low seat height (30.9 - 31.9") and seat ergo's I would have voted Awesome but I am fearing that I just wouldn't be able to fit on this bike (darn it!) and that would really, really bug me as this is such an awesome bike. Great price for a Ducati, great power, great looks, wow, it would be hard to NOT consider this bike as an advanced rider bike! Love it in the Ducati Red too, amazing how good Ducati red looks... the Ducati black, meh. That's like getting a boring old color Ferrari, I wonder how many Ferrari's are sold NOT in red!?
Great bike, like what Ducati has done. But Blues did say it right, the seat, although I'd have to say the seat doesn't look that comfortable at all and I don't think there is much wiggle room on it either for the rider. :(
