were do i ask a question about motor problems
- Real Name: Rob
- Years Riding: 20
- My Motorcycle: 1983 vt750c honda shadow
I have a 83 vt750 c that's hard to start and backfires in carb
Re: were do i ask a question about motor problems
Hi Rob
Welcome to the forums. I moved your question here to the trouble shooting forum. You're more likely to get help in here.
- BRUMBEAR
- Legendary 1000
- Real Name: Dave
- Years Riding: 40
Rob when it does start does it run normally? Does it backfire @ idle or only when loading the motor? Was it sitting for any length of time. Without a little more it's tough to say. I'd start with the usual suspects, worn plugs not really fouled make sure the gap is correct, wires spray wd40 on the plug wires see if it gets better, run seafoam through the fuel. Usually it's something simple.
Dave
Dave
there aint nothin like it
- Johnj
- Real Name: Johnny Strabler
Hello Rob and welcome to the forum. I would start with a complete cleaning of the carburetor. Good luck.
- Real Name: Rob
- Years Riding: 20
I tottaly cleaned the carbs got it running and its back firing in the left hnd carb under throttle. I think the choke cable is the problem.
- Real Name: Rob
- Years Riding: 20
how much pressure should the fuel pump have?
- Real Name: Ryan
Not sure but did you balance the carbs?
- Legendary 300
- Real Name: Ron
Backfire is usually either extremely lean mixture (air leak or plugged carb jets) or wrong timing.
Only time I've actually seen backfire thru the carb was because of crossed spark plug wires on a car that I was working on.....
Ron
Past: 1987 Yamaha XT350
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
1983 Honda CB900F
1980 Honda XL185S
1979 Suzuki GS425E
- Real Name: Rob
- Years Riding: 20
think I solved my problem fuel filter was dirty and no fuel coming outta reserve tank.ty all for your help
Ah there you go! Sometimes the solution is the simplest, cheapest and easiest one*.just wanna ride wrote:think I solved my problem fuel filter was dirty and no fuel coming outta reserve tank.ty all for your help
*I haven't learned this lesson myself yet, but I'm trying.
