2014 Husaberg TE300 - Coolness Factor = 74.6%
Your Coolness Factor of the 2014 Husaberg TE300 is:
View results
2014 Husaberg TE300 on the Total Motorcycle Cool Wall
For A LOT MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... -TE300.htm
The TE 300 truly is the go anywhere, do anything bike – the ultimate Extreme Enduro machine yet equally at home battling for race wins in the Enduro World Championship. With its super-smooth, tractable power the TE 300 excels with an unbeatable power-to-weight ratio. In the hands of Graham Jarvis it’s a bike capable of almost anything. In the hands of the world’s weekend warriors it’s dependable and capable as it is enjoyable and easy to ride.
2014 Husaberg TE300 Key Features Totalmotorcycle.com
New cylinder head with optimised combustion chamber
Newly developed reed valve with Boyesen high performance reeds
Modified ignition mapping for improved motor performance
Refined DDS clutch for unbeatable reliability
Improved carburettor settings for better throttle response
Stronger battery for improved starting
Improved WP PDS settings
SPECIFICATIONS on Totalmotorcycle.com
ENGINE
Design 1-cylinder 2-stroke engine, water-cooled, with reed intake and exhaust control
Displacement 293.2 cm³
Bore 72 mm
Stroke 72 mm
Starting aid Kickstarter and electric starter
Transmission 6 gear, claw shifted
Primary ratio 26:72
Secondary ratio 14:50 (13:50)
Clutch Wet multi-disc clutch DDS / Brembo hydraulics
Ignition system Contactless, controlled, fully electronic ignition system with digital ignition timing adjustment, type Kokusan
CHASSIS
Frame Central tube frame made of chrome molybdenum steel tubing
Fork WP Suspension Up Side Down 4860 4CS
Shock absorber WP Suspension PDS 5018 DCC
Suspension travel Front 300 mm
Suspension travel Rear 335 mm
Brake system Disc brakes, brake calipers on floating bearings
Brake discs - diameter Front 260 mm
Brake discs - diameter Rear 220 mm
Chain 5/8 x 1/4"
Steering head angle 63.5°
Wheelbase 1,482±10 mm
Ground clearance, unloaded 355 mm
Seat height, unloaded 960 mm
Total fuel tank capacity, approx. 10.7 l
Unleaded premium fuel (95 octane), mixed with 2-stroke engine oil (1:60)
Weight without fuel, approx. 102.6 kg
Re: This week: 2014 Husaberg TE300: Vote Today
New for 2014. :revv:
ceemes
Real Name: a big secret
#3 Unread post by ceemes »
Interesting and dramatic photo, looks like the rider is scaling a near vertical rock face....that is until you notice the trees and shrubs in the back ground are some 22.5 degrees off centre to the right......then you realize, he is basically riding over a flat surface.....
Apart from that, not much to say about the bike. Afraid dirt bikes don't do anything for me, and since we still haven't gotten our oft called for "meh" option, I guess I will pass on voting on this one.
HYPERR
#4 Unread post by HYPERR »
totalmotorcycle wrote:New for 2014. :revv:
I don't see what's new for 2014; looks just like the old model. :?
That said, any two smoke is awesome IMO. :kicking:
BRUMBEAR
Real Name: Dave
Years Riding: 40
#5 Unread post by BRUMBEAR »
I went with awesome. My roots are the dirt and as KTM has purchased Husqvarna we may be looking at the last of the Husers that aside it is a wonderful piece of engineering. I also gotta say +1 to Hyper's statement 2 smokers are AWESOME!!!!!!
there aint nothin like it
jstark47
#6 Unread post by jstark47 »
BRUMBEAR wrote:......as KTM has purchased Husqvarna we may be looking at the last of the Husers
The same bike seems to be sold as either a Husaberg or a Husqvarna. I guess it depends which logo you'd prefer on the side of the tank..
JackoftheGreen
Real Name: Eric
#7 Unread post by JackoftheGreen »
ceemes wrote:...that is until you notice the trees and shrubs in the back ground are some 22.5 degrees off centre to the right......then you realize, he is basically riding over a flat surface...
I noticed this too, and although it's not uncommon for trees to grow at a slant on a mountain face, comparing the angle of the cloud layers against the angle of the trees makes it pretty obvious the photo's been altered.
That said, I certainly wouldn't call the actual angle of ascent a flat surface, it's better than 45 degrees. And I'll say this too, although this photo isn't telling the truth, I'm positive this bike -- and a lot of other dirt bikes -- can and do climb angles even more extreme. Two-strokers are just ballsy machines, no two ways about it, this has got 50cc's more displacement than my old KDX and that green machine was a BEAST.
I'd go Awesome, but the electric start feels like a ploy to rope in a buying demographic with slightly deeper pockets -- a feature meant more for the sales floor instead of the mountain or brush. Add to that the PR stunt with the doctored photo, which is just silly, and this drops from an Awesome to a Cool.
JackoftheGreen
Real Name: Eric
#8 Unread post by JackoftheGreen »
With Christmas weekend and New Years on the calendar, I thought maybe this needed a bump...
Only two more days to vote! And with only 14 votes so far, there's still plenty of room for this dirty little smoker to go either way.
BRUMBEAR
Real Name: Dave
Years Riding: 40
#9 Unread post by BRUMBEAR »
I think I voted 2 times sorry
Since you seem critical of the photo, here it is rotated to a flat horizon in Photoshop:
