2015 Yamaha FZ-07 - Voted
Your Coolness Factor of the 2015 Yamaha FZ-07 is:
23
48%
24
50%
1
2%
0
No votes
Total votes: 48
2015 Yamaha FZ-07 on the Total Motorcycle Cool Wall
For MORE photos and information click here: http://www.totalmotorcycle.com/motorcyc ... a-FZ07.htm
2015 Yamaha FZ-07
Conquer the road...
The newest member of the "FZ family", the all new 2015 FZ-07 is a motorcycle that brings fun, affordability and riding enjoyment back to the street. This versatile naked roadster offers deep engine torque and a comfortable riding position in a lightweight, easy to handle sports chassis. It's the perfect machine for both new and experienced riders alike who are looking for outstanding value.
2015 Yamaha FZ-07 Totalmotorcycle.com Key Features
/// Power
All new, liquid-cooled, 689cc, inline twin has been designed to provide deep, powerful torque in the most frequently used rpm range (3,000 to 6,500 rpm). A single balancer shaft keeps things silky smooth, while the 6-speed transmission with overdrive 6th gear reduces engine rpms at highway speeds and enhances the engine's character.
/// Control
The 38mm Mikuni throttle body fuel injection system combines with the 270 degree "Crossplane Concept" CP2 crankshaft to provide easy to use linear throttle response, providing the rider with the ability to control the FZ-07 at will.
/// Style
From the compact "diamond type" frame to the single 60/55 watt headlight to the naked roadster bodywork, the FZ-07's styling highlights its super lightweight of only 180 kgs (397 lbs). The conventional handlebar design and upright riding position translates into all day riding comfort.
2015 Yamaha FZ-07 - http://www.Totalmotorcycle.com Canadian Specifications/Technical Details
Canada MSRP Price: $7,299 CDN
USA MSRP* $6,990 USD
/// ENGINE
ENGINE
Liquid-cooled, DOHC, 8-valves (4-valves/cylinder), inline twin cylinder
DISPLACEMENT
689cc
BORE AND STROKE
80 x 68.6 mm
COMPRESSION RATIO
11.5:1
MAXIMUM TORQUE
6.9 kg-m (50 ft-lbs.) @ 6,500 rpm
FUEL DELIVERY
Mikuni 38 mm dual bore throttle body F.I.
ESTIMATED FUEL CONSUMPTION http://www.Totalmotorcycle.com
24 kpl / 68 mpg (Imp.)
LUBRICATION
Wet sump
IGNITION / STARTING
TCI / Electric
TRANSMISSION
6-speed
FINAL DRIVE
"O"-ring chain
/// CHASSIS
SUSPENSION (FRONT)
41mm fork
SUSPENSION (REAR)
Adjustable link Monocross
BRAKES (FRONT)
Dual 282mm discs / 4-piston calipers
BRAKES (REAR)
245mm disc / single piston caliper
TIRES (FRONT)
120/70ZR17
TIRES (REAR)
180/55ZR17
/// CRITICAL DATA
LENGTH
2,085mm (82.1")
WIDTH
745mm (29.3")
HEIGHT
1,090mm (42.9")
WHEELBASE
1,400mm (55.1")
RAKE / TRAIL
24.5° / 90mm
SEAT HEIGHT
805mm (31.7")
FUEL CAPACITY
14 litres (http://www.Totalmotorcycle.com 3.1 imp. gallons)
WET WEIGHT
180 kg (397 lb.)
COLOUR(S)
Matte Metallic Gray
Bluish White
Vivid Red
Re: This Week: 2015 Yamaha FZ-07 - Vote Today
And here we go a brand-new model for 2015 from Yamaha following up on their FZ-09. Personally, I was a little surprised about the FZ-7 as I thought they would have a FZ-12 or something like that, but still loads of time left in 2014... :D
ceemes
Real Name: a big secret
#3 Unread post by ceemes »
Me likee, however only gave it a cool rating.
pchast
#4 Unread post by pchast »
Like it. A 700.
Sport bike.
Ok its cool.
Grey Thumper
Real Name: Dino
#5 Unread post by Grey Thumper »
A perfect modern day UJM. Awesome.
It's hard not to not like a mid-sized, do-it-all type of bike... heck, it's even naked :D
Update: Now available in the USA. :D
MSRP* $6,990 (Liquid Graphite)
$6,990 (Rapid Red)
$6,990 (Pearl White)
montanalifter
Real Name: Bill
#8 Unread post by montanalifter »
Gave it an awesome, 7k for a good looking naked.
Hanson
Real Name: Richard Hanson
Years Riding: 3
#9 Unread post by Hanson »
The mid range displacement market is starting to fill up with some nice options.
JackoftheGreen
Real Name: Eric
#10 Unread post by JackoftheGreen »
Certainly looks like a fun machine, absolutely the sort of thing I'd like to test ride if I ever dip a toe into this segment.
I don't think it's a beginners bike, there's just a little too much performance to put a new rider in command of. Also, it's a shame they put together this excellent platform, dialed in a stunning 68mpg, and then castrated it with a three gallon tank. Another gallon under the gap would have given this real touring chops, as is, it can't quite lend itself to that application.
So, I downgrade from an Awesome to a solid Cool.
