2015 Victory Vision Tour - Coolness Factor = 47.1%
Your Coolness Factor of the 2015 Victory Vision Tour is:
12
32%
9
24%
10
26%
7
18%
Total votes: 38
2015 Victory Vision Tour on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... 150-3V.htm
2015 Victory Vision Tour on http://www.Totalmotorcycle.com
One great ride...
The Victory Vision redefines what a touring motorcycle can be with its outstanding combination of a great ride, ample storage, superior comfort and distinctive style that could only come from Victory Motorcycles.
2015 Victory Vision Tour http://www.Totalmotorcycle.com Features
106 CUBIC-INCH FREEDOM® V-TWIN
The Victory® Freedom® 106/6 V-Twin is a 106-ci powerplant that provides Victory Vision Tour riders with 108 ft-lb of torque. Smooth, powerful, and efficient, it’s a counter-balanced and fuel-injected engine that delivers confidence-inspiring performance for touring riders who like to lead, not follow.
6-SPEED OVERDRIVE TRANSMISSION
Every gear shift is smooth and defined with the Victory 6-speed transmission with true overdrive. It syncs up with the outstanding power of the Victory Freedom® 106/6 V-Twin and its helical-cut gears ensure that each shift is sure and smooth. During interstate cruising, 6th gear overdrive drops the RPMs and delivers the smooth ride you’ve been looking for, and to enhance fuel mileage and extend the range of a tank of fuel.
HEATED HANDGRIPS & INDIVIDUAL HEATED SEATS
Extend the riding season with the heated handgrips and heated seats. There’s a choice of Hi & Lo settings for the heated handgrips, and the heated seats have individual driver and passenger controls with Hi & Lo settings. You can add a month or more on both ends of the riding season with the flip of a switch.
29 GALLONS OF TRUNK & SADDLEBAG SPACE
Integrated in the smooth-flowing lines of the Victory Vision Tour are convenient side storage compartments and a spacious trunk. These storage spaces combine to offer one or two riders ample space for their touring gear. The side compartments and trunk are weather-sealed and lockable. The trunk has an integrated, padded passenger backrest and dual audio speakers that combine with the fairing speakers for surround sound. http://www.Totalmotorcycle.com
CONFIDENCE-INSPIRING LINKED ABS BRAKING
Victory Vision Tour riders ride with confidence, knowing their stopping power includes the Victory Linked Anti-Lock Brake System. It monitors the wheels and when it senses compromised traction, it instantly and automatically provides braking for quick stopping under control.
CRUISE CONTROL
Once you’re out on the open road, activate the cruise control to enjoy easy, relaxed cruising. This automotive-quality cruise control is easy to activate and set, and it reliably maintains the desired speed. To de-activate it, simply press “Off” or engage the clutch or brake.
POWER WINDSHIELD & FULL-COVERAGE FRAME MOUNTED FAIRING
With the power windshield, you manage airflow reaching the riders by raising and lowering the windshield with the push of a button. The frame-mounted fairing provides the ultimate in wind and weather protection and lets riders enjoy the ride in all conditions.
ULTRA-SMOOTH REAR SUSPENSION TRAVEL
If you encounter a rough patch of road, the plush Victory Vision Tour rear suspension keeps the ride smooth and steady with 3.65” of travel. Keep the ride consistently smooth with the easy-adjust air shock. Consult the air pressure chart, adjust the air shock with a hand pump and enjoy the incredibly smooth ride – whether you’re riding solo or 2-up, with or without cargo on board.
2015 Victory Vision Tour - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $20,999 USD
Canada MSRP Price: $23,499
Specifications
Dry Weight 869 lbs / 394 kg
Displacement 106 ci / 1731 cc
Oil Capacity 5.0 qts / 4.73 ltr
ENGINE & DRIVETRAIN
Battery 12 volts / 18 amp hours
Charging System 48 amps max output
Compression Ratio 9.4 : 1
Cooling Air / oil
Drive/Driven Clutch Wet, multi-plate
Exhaust Split dual exhaust with crossover
Transmission Type 6-speed overdrive constant mesh
Transmission/Final Drive Carbon Fiber Reinforced Belt
Transmission/Primary Drive Gear drive with torque compensator
Valve Train Single overhead camshafts with 4 valves per cylinder, http://www.Totalmotorcycle.com, self-adjusting cam chains, hydraulic lifters
Bore x Stroke (mm) 101 x 108 mm
Engine Type 4-stroke 50° V-Twin
Suspension
Front Suspension Conventional telescopic fork, 46 mm diameter, 5.1 in / 130 mm travel
Rear Suspension Single, mono-tube, cast aluminum with constant-rate linkage, 4.7 in / 92.7 mm travel, air adjustable
Brakes
Brake System Type Linked w/ ABS
Front Brakes Dual 300mm floating rotors with 4-piston calipers
Rear Brakes 300mm floating rotor with 2-piston caliper
Tires / Wheels
Front Tires 130/70R18 Dunlop Elite 3
Front Wheel 18 x 3.5 in
Rear Tires 180/60R16 Dunlop Elite 3
Rear Wheel 16 x 5.0 in
DIMENSIONS
Fuel Capacity (gallons/liters) 6.0 gal / 22.7 ltr
Ground Clearance 5.8 in / 148 mm
GVWR 1414 lbs / 643 kg
Rake/Trail 29.0° / 5.4 in / 137 mm
Seat Height 26.5 in / 673 mm
Wheelbase 65.7 in / 1670 mm
Overall Length (in./cm.) 106.4 in / 2702 mm
Features http://www.Totalmotorcycle.com
Colors Gloss Black, Sunset Red with Black Pinstripe
Re: This Week: 2015 Victory Vision Tour - Vote Now
When looking at what bike to make this week's Cool Wall bike I noticed we haven't yet had a Victory Vision up on the Cool Wall all these years! With Victory's success at this model I figured it was time.
montanalifter
Real Name: Bill
#3 Unread post by montanalifter »
Different looking but that's ok, would like to see one in the showroom as bikes always look better in person. Would make a great two up bike for the open road. Love the heated seats and grips, lots of storage room.
ceemes
Real Name: a big secret
#4 Unread post by ceemes »
Fail. Suzuki did in first and better with the Boulevard M109R.
HYPERR
#5 Unread post by HYPERR »
Wow mfugly as sin! :shock:
Fail :?
faded sun
Years Riding: 46
#6 Unread post by faded sun »
I have seen but not ridden these monsters and I can say I wouldn't mind all that gear if I was really on tour. As I plan a cross-continental tour in the near future I am measuring out the qualities of my ST 1100 and deciding if I can ride one all the way to LA.
It's cool for me.
Jock
ceemes
#7 Unread post by ceemes »
HYPERR wrote:Wow mfugly as sin! :shock:
Fail :?
It's even uglier in person...........they had vomit bags and buckets around it at the Vancouver Bike Show this weekend.
ibanrfknm
Real Name: Art
Years Riding: 50
My Motorcycle: FXDBI
#8 Unread post by ibanrfknm »
Cosmetically I have never liked the Vision but after riding along side one I will say they are quiet, fast and handle quite well.
Grey Thumper
Real Name: Dino
#9 Unread post by Grey Thumper »
Oddly-proportioned, bloated, vulgar, garish, and all that bling dates what is actually a relatively new design. If you're in the market for a full-dress tourer, there are far better-looking ones out there.
Hanson
Real Name: Richard Hanson
Years Riding: 3
#10 Unread post by Hanson »
This is certainly not the bike for me, but there are people who love this motorcycle. I think the aesthetics of this bike are both bold and polarizing. When I look past the body work, I don't see how this motorcycle is any more objectionable than any H-D full dresser. Both are rather ugly, but at least the Victory does not come with all the extra baggage of the H-D subculture.
If I was ever to buy a motorcycle in this segment of the market I think it wold be an Indian Roadmaster. Realistically, I am very unlikely to have any of these machines.
Fail? I don't thinks so. I give this bike an uncool, but I also expect this bike to push a lot of people to the lower margins of the Total Motorcycle rating system. The Vision is what it is and for those few that find her aesthetics pleasing, they have a ride that sets them apart from the typical conformists in the pirate crowd.
Safe Travels,
Richard
