82 yamaha xj550 stalling
jbob286
#1 Unread post by jbob286 »
Hey all, I let my bike sit for 10 days or so and had a hell of a time starting it which is normal for my bike when it has sat for a while. It probably needs a tuneup. Anyways the bike stalls everytime once I let off the gas or put the clutch in for longer than a second. It doesn't idle or struggle to keep running the rpms just drop at a constant speed until the engine dies. This happens even after the engine has warmed up properly. Could be that the idle speed adjustment got messed up? Should I try a tuneup, replacing the spark plugs I know haven't been done in a while. Carbs were synched and I believed cleaned before the bike was sold to me a month or so ago.
TechTMW
#2 Unread post by TechTMW »
Alot of old yamahas seem to have the startup problem. If the bike has been sitting, out the petcok in the PRI position to let the carbs fill up w/ fuel foe about 10 seconds
Your running problem sounds like it's a clogged idle circuit - very good possibility that crud has collected in the passages under the idle mix screws. This is difficult to clean. requres a soak and compressed air usually.
If you try to cleean yourself, be very careful. The idle mix screws strip easily, and afaik they are unobtanium.
Aggroton
#3 Unread post by Aggroton »
yeah the pri wil defiantly help starting issues...and tune ups are never a bad idea....and post some pics! :wink:
thats a sweet bike.
