So as I new rider I was hoping someone could shed light on this situation. Tire has new tubes but the tire itself has some dry rot However, I rode on it a few times no issues
here is a pic ( the dry rot is only on part of the tire) gif upload
There is no "I think" to this issue....."DO NOT RIDE THAT BIKE AGAIN UNTIL YOU REPLACE THAT TIRE; IF YOU PUT ANY VALUE ON YOUR LIFE & THE LIVES OF THOSE AROUND YOU". You're playing Russian Roulette with 5 out of 6 chambers loaded!!!!!! I think that you need to check the front tire also. "ANY" dry rot is too much.
Hello John welcome to the forum. You should look into replacing your tires soon. I would not ride on tires like that.
Jacksprat56 wrote:There is no "I think" to this issue....."DO NOT RIDE THAT BIKE AGAIN UNTIL YOU REPLACE THAT TIRE; IF YOU PUT ANY VALUE ON YOUR LIFE & THE LIVES OF THOSE AROUND YOU". You're playing Russian Roulette with 5 out of 6 chambers loaded!!!!!! I think that you need to check the front tire also. "ANY" dry rot is too much.
oh I didn't think it was that bad. I'll get it replaced before I ride it again. P.S. That is the front tire....Back tire is fine with not dry rott or anything like that.
