new and need help asap!!!!! please!!!!
suki600
Real Name: tyler
Years Riding: 1
My Motorcycle: 2001 gsx600
#1 Unread post by suki600 »
i have a 2001 Suzuki gsx600f and it has sat for 8 months has been started or ran.
what do i need to do to get it running in tip top shape.
had some troubles getting it started, once i did the front of the left two carbs was leaking that stopped. then it started running rough.
it idles high then will will act like its getting no gas to the motor and will studder and shut off but will crank back up and then do the same thing.
i have a buddy who rides he told me to clean carbs, change oil, oil filter, fuel filter, and spark plugs and wires.
he also told to drain old gas, and other fluids and replace.
is there anything else i need to do and or try something different im trying to be up and riding by monday at the latest!
Re: new and need help asap!!!!! please!!!!
First of all...Welcome to TMW.
Have you actually done that yet?
blues2cruise wrote:First of all...Welcome to TMW.
That would be the BASICS of what I would suggest as well. Only things I could add would be:
Check the battery strength
Check the air filter
suki600
Real Name: tyler
Years Riding: 1
#4 Unread post by suki600 »
Yes I have done everything but it has a problem starting now like I have to put it in gear push it backwards for half a wheel turn before I'm able to start it
suki600
Real Name: tyler
Years Riding: 1
#5 Unread post by suki600 »
It also has brand new battery , terminals and air and in line fuel filter
suki600
Real Name: tyler
Years Riding: 1
#6 Unread post by suki600 »
And it's not every start only if it's been sitting for 3 or more hours
