throttle by wire
tailfinn
Real Name: Paul
My Motorcycle: 2010 HD Elctra Glide
throttle by wire
#1 Unread post by tailfinn »
the other day , my throttle by wire went limp.... only had idle ( or a little more ) shut down bike for maybe 10 / 12 mins. , started up and all was well . Anyone have experience with this, anything I should check out , any sort of maintenance
thanks
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
Re: throttle by wire
#2 Unread post by Gummiente »
This has apparently been an issue since day one with the fly by wire system. There was a maintenance notice issued a few years ago that advises all owners to have the connection pins on the ECM checked every 8000mi, as apparently they become damaged over time especially if the bike is ridden on rough roads. In severe cases this will cause the engine to go into "limp" mode until it has been reset and/or repaired. You may want to consult with your dealer about this.
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
