Changing out a headlight
- NorthernPete
- Real Name: Pete
- Years Riding: 11
Want to change out my headlight on my 82 sr250. Would like to replace the sealed beam with a led day maker. Most of them are 75w led. Would this be alright to use instead? Won't catch my bike on fire or kill battery? And it's a three prong socket on there now, would the h3 or h4 plug just plug right in?
2009 GS500F
2009 GS500F
- Gummiente
- Years Riding: 38
Re: Changing out a headlight
LED headlights are brighter than sealed beams and H4 bulbs and draw less power. This means more illumination with much less heat; the 75W rating means that it is equivalent in illumination to what a traditional 75W light would produce. They are designed as a "plug and play" unit, so you should have no issues installing it in your headlight shell using the OEM headlight plug. It will not kill the battery or melt the wiring, as it will be using approx half the power of the stock headlight.
A word of caution about LED headlight use; the beam they produce is wide and flat and works great at night on straight roads, but when you lean the bike over into a corner the beam pattern tilts, too, which reduces visibility on the road ahead until the bike is level again.
![Canada :canada:](./images/smilies/smilie_flag_Canada.gif)
![Republic of Gummiente :gummiente:](./images/smilies/smilie_flag_RepublicOfGummiente.gif)
It isn't WHAT you ride,
It's THAT you ride
- Johnj
- Real Name: Johnny Strabler
There's a company called Candlepower that makes a H4 Headlamp Replacement Kit for 7 inch round headlights. I think they also make the smaller size one.
![Image](http://i64.tinypic.com/wsu2on.jpg)
- Real Name: Chris
- Years Riding: 0
- My Motorcycle: 2005 Swift Bar Chopper CSF
I have a 2005 Swift Bar Chopper, and swapping out the big round standard headlight, for an aftermarket LED light, is one of the first mods I'd like to do.
Being a complete noob at motorcycles, how do I know if I can install it in place of my OEM one or, which one I'd need for replacement?
- Sundog65
- Real Name: Bill
- Years Riding: 1
- My Motorcycle: 2009 Yamaha V-Star 1100 Classic
I just got an LED headlight and this is really good to know. Thanks.Gummiente wrote: ↑Fri Jun 03, 2016 10:47 pm LED headlights are brighter than sealed beams and H4 bulbs and draw less power. This means more illumination with much less heat; the 75W rating means that it is equivalent in illumination to what a traditional 75W light would produce. They are designed as a "plug and play" unit, so you should have no issues installing it in your headlight shell using the OEM headlight plug. It will not kill the battery or melt the wiring, as it will be using approx half the power of the stock headlight.
Don't try to win over the haters. You're not the jackass whisperer.
- NorthernPete
- Real Name: Pete
- Years Riding: 11
Love my led bulb. So much brighter then the stock one. Very happy that I did this!
2009 GS500F
2009 GS500F
- Site Supporter - Silver
- Real Name: Pete
- Years Riding: 10
Easily blinding for oncoming traffic. Please, have a helper
ensure that your headlight aim is right.
- NorthernPete
- Real Name: Pete
- Years Riding: 11
Yeah, I used my garage door and measuring tape to ensure proper aim.
2009 GS500F
2009 GS500F
