Thanks
Becca
This is also a Kawasaki thing poppy. Kawasaki (and maybe others now but I've only seen in on Kaw's) use a vacuum operated valve to stop fuel to carbs. If the engine is off, the switch is off. So you have these three choices - 1. "on" for normal service 2. "res" for when run out the main quantity 3. "Pri" to primer the carbs when they are bone dry. Pri is really a vacuum switch by-pass.poppygene wrote:Sorry, Becca... my bad, yours is the older type petcock.
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
