2017 Ducati SuperSport S - Coolness Factor = 85.5%
Posted: Fri Dec 23, 2016 5:37 am
2017 Ducati SuperSport S on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... port-S.htm
2017 Ducati SuperSport S on http://www.Totalmotorcycle.com
More sport, every day...
Ducati presents the SuperSport, the bike for those eager to ride sports-style on everyday roads. Fun and versatile with true Ducati sports styling and zest, the SuperSport makes riders feel like racers: every day.
The Ducati Design Center has come up with a dynamic, polished, visually compact, light machine with strong Panigale superbike overtones: a Ducati to the core. A lean and mean road machine, the SuperSport has an approachable feel thanks to easy handling, the confidence-inspiring Ducati Safety Pack (ABS Bosch + Ducati Traction Control), the awesome price-quality ratio of the equipment and the long maintenance intervals.
Agile on city streets, comfortable on the motorway and superlative on out-of-town twisties, the SuperSport is super-versatile. Relaxed rider and passenger positions, good airflow deflection from the height-adjustable Plexiglas screen and the mileage provided by the 16-litre fuel tank also make the new Ducati SuperSport a cool companion on medium-distance rides.
The SuperSport range includes a SuperSport S version with fully adjustable Öhlins suspension, the Ducati Quick Shift up/down system and a rear seat cover: the latter are also available as accessories for the SuperSport.
Powering the SuperSport is a twin-cylinder 937 cm³ Testastretta 11° engine. This delivers 113 hp at 9,000 rpm and a full yet linear torque curve that peaks at 96.7 Nm at 6,500 rpm. Thanks to the three Riding Modes (Sport, Touring and Urban), the SuperSport's temperament can be adapted to ensure maximum enjoyment whatever the riding conditions. Each Riding Mode can, of course, be customised, allowing the bike to be set up quickly to suit personal preferences and riding skills.
The SuperSport frame is the latest development of the famous Trellis design that exploits the engine as a load-bearing element.
Compact, light and rigid, it plays a pivotal role in making the SuperSport swift at the drop-in, yet also an instinctual machine that can be ridden by everyone. Intelligent frame configuration has played a key role in keeping wet weight down to around 210 kg. Superb chassis geometry, above all the 1,478 mm wheelbase and 180/55 rear tyre, makes the SuperSport easy to handle on both city streets and mountain hairpins, maximising stability on bends and at speed.
As one would expect from Ducati, the SuperSport can be fitted with a full range of Ducati Performance accessories (some are included in the Sport, Touring and Urban packages) that let owners configure the bike to suit personal wants and needs.
Expert riders will appreciate the true sports personality of the SuperSport, its excellent road performance and an evident penchant for journeying and everyday use. Riders approaching the Ducati sports world for the first time will discover dazzling versatility, easy handling and, above all, the very essence of sports riding as Ducati sees it.
2017 Ducati SuperSport S - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $ See Dealer for Pricing in USD
Canada MSRP Price: $ See Dealer for Pricing in CDN
Engine
Testastretta 11°, L-Twin cylinder, 4 valve per cylinder, Desmodromic, liquid cooled
Displacement
937 cm³
Bore X stroke
94 x 67.5 mm (3.7 x 2.66 in)
Compression ratio
12.6± 0.5 :1
Power
83.1 kW (113 hp) @ 9,000 rpm
Torque
96.7 Nm (71.3 lb-ft) @ 6,500 rpm
Fuel injection
Continental electronic fuel injection system, 53 mm Mikuni throttle bodies with full Ride-by-Wire
Exhaust
Lightweight 2-1-2 system with catalytic converter and two lambda probes. Twin aluminium mufflers
Gearbox
6 speed
Primary drive
Straight cut gears; Ratio 1.84:1
Ratio
1=37/15 2=30/17 3=28/20 4=26/22 5=24/23 6=23/24
Final drive
Chain; Front sprocket 15; Rear sprocket 43
Clutch
Wet multiplate clutch mechanically operated, self-servo action on drive, slipper action on over-run
Frame
Tubular steel Trellis frame attached to the chylinders head
Front suspension
Fully adjustable 48mm (1.9 in) usd Ohlins forks
Front wheel
Y shaped, 3-spoke in light alloy 3.50" x 17"
Front tyre
Pirelli Diablo Rosso III 120/70 ZR17
Rear Suspension
Progressive linkage with fully adjustable Ohlins monoshock. Aluminium single-sided swingarm
Rear Wheel
Y shaped, 3-spoke in light alloy 5.50" x 17"
Rear tyre
Pirelli Diablo Rosso III 180/55 ZR17
Wheel travel (front/rear)
130/144 mm (5.12/5.67 in)
Front brake
2 x 320 mm (12.6 in) semi-floating discs, radially mounted Monobloc Brembo M4-32 callipers, 4-piston, radial pump with ABS as standard
Rear brake
245 mm (9.6 in) disc, 2-piston caliper, ABS as standard
Instrumentation
LCD display
Dry weight
184 kg (406 lb)
Kerb weight
210 kg (463 lb)
Seat height
815 mm (32.1 in)
Wheelbase
1478 mm (58.2 in)
Rake
24°
Front wheel trail
91 mm (3.6 in)
Fuel tank capacity
16 l (4.2 US gal)
Number of seats
2
Riding Modes, Power Modes, Ducati Safety Pack (ABS + DTC), RbW, DQS, seat cover. Ready for anti-theft system
Warranty (months)
24 months unlimited mileage
Maintenance (km/months)
15,000 km (9,000 mi) or 12 months
Valve clearance adjustment
30,000 km (18,000 mi)
Euro 4
Engine
Displacement
937 cm³
Bore X stroke
Compression ratio
12.6± 0.5 :1
Power
Torque
Fuel injection
Exhaust
Gearbox
6 speed
Primary drive
Ratio
Final drive
Clutch
Frame
Front suspension
Front wheel
Front tyre
Rear Suspension
Rear Wheel
Rear tyre
Front brake
Rear brake
Instrumentation
LCD display
Dry weight
184 kg (406 lb)
Kerb weight
210 kg (463 lb)
Seat height
815 mm (32.1 in)
Wheelbase
1478 mm (58.2 in)
Rake
24°
Front wheel trail
91 mm (3.6 in)
Fuel tank capacity
16 l (4.2 US gal)
Number of seats
2
Warranty (months)
Euro 4
