2017 Ducati SuperSport S - Coolness Factor = 85.5%
Your Coolness Factor of the 2017 Ducati SuperSport S is:
View results
Unread post by totalmotorcycle » Fri Dec 23, 2016 11:37 am
2017 Ducati SuperSport S on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... port-S.htm
2017 Ducati SuperSport S on http://www.Totalmotorcycle.com
More sport, every day...
Ducati presents the SuperSport, the bike for those eager to ride sports-style on everyday roads. Fun and versatile with true Ducati sports styling and zest, the SuperSport makes riders feel like racers: every day.
The Ducati Design Center has come up with a dynamic, polished, visually compact, light machine with strong Panigale superbike overtones: a Ducati to the core. A lean and mean road machine, the SuperSport has an approachable feel thanks to easy handling, the confidence-inspiring Ducati Safety Pack (ABS Bosch + Ducati Traction Control), the awesome price-quality ratio of the equipment and the long maintenance intervals.
Agile on city streets, comfortable on the motorway and superlative on out-of-town twisties, the SuperSport is super-versatile. Relaxed rider and passenger positions, good airflow deflection from the height-adjustable Plexiglas screen and the mileage provided by the 16-litre fuel tank also make the new Ducati SuperSport a cool companion on medium-distance rides.
The SuperSport range includes a SuperSport S version with fully adjustable Öhlins suspension, the Ducati Quick Shift up/down system and a rear seat cover: the latter are also available as accessories for the SuperSport.
Powering the SuperSport is a twin-cylinder 937 cm³ Testastretta 11° engine. This delivers 113 hp at 9,000 rpm and a full yet linear torque curve that peaks at 96.7 Nm at 6,500 rpm. Thanks to the three Riding Modes (Sport, Touring and Urban), the SuperSport's temperament can be adapted to ensure maximum enjoyment whatever the riding conditions. Each Riding Mode can, of course, be customised, allowing the bike to be set up quickly to suit personal preferences and riding skills.
The SuperSport frame is the latest development of the famous Trellis design that exploits the engine as a load-bearing element.
Compact, light and rigid, it plays a pivotal role in making the SuperSport swift at the drop-in, yet also an instinctual machine that can be ridden by everyone. Intelligent frame configuration has played a key role in keeping wet weight down to around 210 kg. Superb chassis geometry, above all the 1,478 mm wheelbase and 180/55 rear tyre, makes the SuperSport easy to handle on both city streets and mountain hairpins, maximising stability on bends and at speed.
As one would expect from Ducati, the SuperSport can be fitted with a full range of Ducati Performance accessories (some are included in the Sport, Touring and Urban packages) that let owners configure the bike to suit personal wants and needs.
Expert riders will appreciate the true sports personality of the SuperSport, its excellent road performance and an evident penchant for journeying and everyday use. Riders approaching the Ducati sports world for the first time will discover dazzling versatility, easy handling and, above all, the very essence of sports riding as Ducati sees it.
2017 Ducati SuperSport S - http://www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $ See Dealer for Pricing in USD
Canada MSRP Price: $ See Dealer for Pricing in CDN
Engine
Testastretta 11°, L-Twin cylinder, 4 valve per cylinder, Desmodromic, liquid cooled
Displacement
937 cm³
Bore X stroke
94 x 67.5 mm (3.7 x 2.66 in)
Compression ratio
12.6± 0.5 :1
Power
83.1 kW (113 hp) @ 9,000 rpm
Torque
96.7 Nm (71.3 lb-ft) @ 6,500 rpm
Fuel injection
Continental electronic fuel injection system, 53 mm Mikuni throttle bodies with full Ride-by-Wire
Exhaust
Lightweight 2-1-2 system with catalytic converter and two lambda probes. Twin aluminium mufflers
Gearbox
6 speed
Primary drive
Straight cut gears; Ratio 1.84:1
Ratio
1=37/15 2=30/17 3=28/20 4=26/22 5=24/23 6=23/24
Final drive
Chain; Front sprocket 15; Rear sprocket 43
Clutch
Wet multiplate clutch mechanically operated, self-servo action on drive, slipper action on over-run
Frame
Tubular steel Trellis frame attached to the chylinders head
Front suspension
Fully adjustable 48mm (1.9 in) usd Ohlins forks
Front wheel
Y shaped, 3-spoke in light alloy 3.50" x 17"
Front tyre
Pirelli Diablo Rosso III 120/70 ZR17
Rear Suspension
Progressive linkage with fully adjustable Ohlins monoshock. Aluminium single-sided swingarm
Rear Wheel
Y shaped, 3-spoke in light alloy 5.50" x 17"
Rear tyre
Pirelli Diablo Rosso III 180/55 ZR17
Wheel travel (front/rear)
130/144 mm (5.12/5.67 in)
Front brake
2 x 320 mm (12.6 in) semi-floating discs, radially mounted Monobloc Brembo M4-32 callipers, 4-piston, radial pump with ABS as standard
Rear brake
245 mm (9.6 in) disc, 2-piston caliper, ABS as standard
Instrumentation
LCD display
Dry weight
184 kg (406 lb)
Kerb weight
210 kg (463 lb)
Seat height
815 mm (32.1 in)
Wheelbase
1478 mm (58.2 in)
Rake
24°
Front wheel trail
91 mm (3.6 in)
Fuel tank capacity
16 l (4.2 US gal)
Number of seats
2
Riding Modes, Power Modes, Ducati Safety Pack (ABS + DTC), RbW, DQS, seat cover. Ready for anti-theft system
Warranty (months)
24 months unlimited mileage
Maintenance (km/months)
15,000 km (9,000 mi) or 12 months
Valve clearance adjustment
30,000 km (18,000 mi)
Euro 4
2017 Motorcycle Model Guides
Re: This Week: 2017 Ducati SuperSport S - VOTE NOW
Unread post by totalmotorcycle » Fri Dec 23, 2016 11:39 am
NEW FOR 2017!!
As requested by High_Side, here is the PERFECT bike for the Christmas stretch being shiny, new and in snow white with red accents.
Make sure to take a look into the updated 2017 Ducati Total Motorcycle Model Guide, I think it's the best guide this year that blows what you get at the other sites out of the water.
Enjoy!
markdcoco
Real Name: Mark DiCocco
My Motorcycle: 2014/BMW/R1200RT
Unread post by markdcoco » Fri Dec 23, 2016 1:36 pm
A "Monster" with a sexy front end. Hope the price point is right. Looks like it would be a pleasure to own and ride.
faded sun
Years Riding: 42
Unread post by faded sun » Sat Dec 24, 2016 12:02 am
All that and it seats 2! LOL
Nice looking bike and a beautiful shot for the promo. Other than the 'scrambler', not sure I've seen a Ducati I didn't like. But, what's the bottom line? Not really fair when you don't know what it's gonna cost you....
Jock
montanalifter
Real Name: Bill
My Motorcycle: Yamaha FJR 1300, Yamaha Stratoliner
Unread post by montanalifter » Sun Dec 25, 2016 3:48 pm
I am usually a function over form person but this bike looks great. Not bad function either. I voted Awesome.
Grey Thumper
Real Name: Dino
Unread post by Grey Thumper » Mon Dec 26, 2016 3:52 am
Beyond awesome. I'd even consider this bike SubZero.
Sometimes you want a beautiful Italian sportbike, but don't want to live with painful ergonomics or ridiculous power and torque curves, or you want to ride it everyday, or ride it the whole day. If that's what you're looking for, the SuperSport is it. I can't actually think of a competitor to this bike. Maybe the KTM 1290, SuperDuke GT, Triumph Tiger Sport, Ducati Multistrada, or BMW X1000XR (none of which are as good looking as the SuperSport, and all of them are also more expensive). The Japanese have been masters at useable sportbikes for quite some time now, but it's nice that finally you can have fun and practicality, with some Italian desirability thrown in.
Years Riding: 41
Unread post by High_Side » Thu Dec 29, 2016 8:37 am
I see this bike as an upscale modern take by Ducati on Honda's VFR. I have a weakness for white Ducati's and this bike looks amazing and I would probably be first in line if Ducati had never made the Multistrada. Now I am addicted to the more upright riding position I am not sure if I can ever go back though. Maybe a test ride would seal the deal..... Can't wait to try one.
Unread post by totalmotorcycle » Fri Dec 30, 2016 11:35 am
I went with: Awesome
What a looker! Red rims, pearl white paint, gold accents... ya, they had me at Red rims...lol. The SuperSport S is definitely aimed at those who want a good premium bike and have some extra dosh in their pocket. It wouldn't be a bad way to roll as it is a mix of what most riders want, power, beauty, comfort and class. While I like an even more upright motorcycle I'm not going to let that spoil my vote as this isn't what the bike is. 133hp and 73 torque is very nice, but the torque comes on a little high though (6500 rpm), which means it either loves to revv or is/was intended to ride more like a triple (sportbike) engine.
The other 2017 Ducati's are coming in quite high priced this year, I'm a little worried we are looking at a $15,000 - $16500 range... but crossing my fingers it is closer to $13k. Which would still be a premium for a 900cc class bike, but yet offer enough to justify the quality.
Unread post by sunshine229 » Fri Dec 30, 2016 11:43 am
Mike gave me a last minute chance to vote on this one and I went with AWESOME! This is a fabulous looking bike and with it being more upright I would consider it.
EDIT: I just saw the result, and just sayin', ONE VOTE CAN MAKE A DIFFERENCE... make sure you vote every week!!!
Unread post by totalmotorcycle » Fri Dec 30, 2016 11:44 am
....and the 2017 Ducati SuperSport S finishes off our 2016 Total Motorcycle Cool Wall!
53 bikes this year participated!
For the next two weeks, I have up the People's Choice Award for best:
- Best Sport Bike of 2016
- Best Standard of 2016
- Best Cruiser of 2016
- Best Adventure/Touring bike of 2016
- People's Choice Award for the top 5 bikes.
Make sure to vote, heck, tell your friends/family to vote too!
Unread post by totalmotorcycle » Fri Dec 30, 2016 12:16 pm
Featured: December 23rd - December 30th, 2016
Motorcycle Cool Wall discussion: viewtopic.php?f=61&t=54043
Total Motorcycle model page: http://www.totalmotorcycle.com/motorcyc ... port-S.htm
Awesome (3 points) 61% [ 14 ]
Cool (2 points) 35% [ 8 ]
Uncool (1 point) 4% [ 1 ]
Fail (0 point) 0% [ 0 ]
Total votes: 23
= a Coolwall Factor of 85.5%
Notes: Ironically, the last bike of 2016 finishes in the #1 spot, taking it away from the 2017 Indian Scout FTR750 which held the #1 spot since early August. Our readers heaped praise onto the new 2017 Ducati SuperSport S loving the idea, style, looks and comfort of the bike, but a grey cloud still hangs over the 2017 Ducati SuperSport S... the price, which as of writing, is unknown. Could a high price ruin what would otherwise be a very sunny day for the 2017 Ducati SuperSport S?
Users browsing this forum: montanalifter, Yahoo [Bot] and 115 guests
cron
