Hi everyone! I have a GPZ 900 cafe/street fighter project in which I have swapped in a 1986 GPZ 1000 engine. I've attached some pictures if you're interested!
Anyways, the engine isn't running properly. The exhaust is a custom with duel 2.25 ID glass pack mufflers. The carbs currently have K/N duel pods as show in the attached images.
Due to the modifications to the chassis and battery relocation the stock airbox will not fit. In the spring I may fabricate an aluminum intake manifold that can fit in that space which will flow air "similar" to the stock system.
So here's my 2 questions:
1) What size jets would you suggest for the new exhaust and stock airbox?
2) What size jets would you suggest for the new exhaust and the k/n pod filters?
Thanks in advance!
Re Jetting Suggestions
- Real Name: Evan
- Years Riding: 6
- My Motorcycle: 1986 GPZ 1000 Cafe Racer
- cafepic2.jpg (118.55 KiB) Viewed 25061 times
- cafepic1.jpg (118.75 KiB) Viewed 25061 times
- kawi pods.JPG (44.15 KiB) Viewed 25061 times
- Real Name: Evan
- Years Riding: 6
Re: Re Jetting Suggestions
anyone?
- Gummiente
- Years Riding: 38
You can't just throw out an accurate answer to questions like these, there are far too many variables. Start with two sizes up from stock and make sure to use a sync tool when making adjustments. You should also raise the jet needles a notch or two as well.
It isn't WHAT you ride,
It's THAT you ride
