For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... uke-GT.htm
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2017/2017-KTM-1290-Super-Duke-GT2-small.jpg)
![Image](http://cdn-0.totalmotorcycle.com/motorcycles/2017/2017-KTM-1290-Super-Duke-GT4-small.jpg)
2017 KTM 1290 Super Duke GT on www.Totalmotorcycle.com
Adrenaline...
The 1290 Super Duke R got us thinking. What if we could match The Beast’s interstellar performance to all day, two-up comfort? What if we would train the most dynamic naked bike ever to race any paved road the world has on offer? Regardless of the weather. Over and over again. So we brought out the big guns, aiming for state-of-the-art ergonomics, electronics and extreme stamina. The result is a long distance V-twin rocket that proudly roars past the top of the food chain, hungry for more. For miles. The faster, the better. A motorcycle that is equally happy hunting horizons, as it is chasing superbikes. And crushing them – not only at cruising speeds. Welcome to the world of the 1290 Super Duke GT, where refinement, comfort, speed and ultimate performance rule.
2017 KTM 1290 Super Duke GT www.Totalmotorcycle.com Key Features
Long distance thrills.
WP semi-active suspension
Road-hugging handling
With 3 ride options including ‘Comfort’, ‘Street’ and ‘Sport’, the innovative WP semi-active suspension system adapts damping in real-time to the riding surface and weight distribution on the bike.
High-tech electronic assistance
Speed off more easily
MSC (Motorcycle Stability Control) features Cornering ABS and has an optional Supermoto mode.
Together with MTC (Motorcycle Traction Control), these features let you ride harder for longer with your wheels firmly on the road.
PreviousNext
Practical features like Cruise Control, ATIR (Automatic Turn Indicator Reset) and TPMS (Tire Pressure Monitoring System) make those longer trips effortless.
MSR (Motor Slip Regulation) ensures sudden deceleration is always smooth and predictable, while HHC (Hill Hold Control) keeps steep pull-offs easy and LED cornering lights with integrated LED indicators maximize cornering safety.
1301 cc motor
Limitless V-twin power
The 1290 Super Duke R’s cylinders were adapted to specially developed GT cylinder heads and a new crankshaft. With 144 Nm max. torque - of which 114 Nm is on tap from just 3250 rpm. Can you say READY TO RACE?
Exceptional adjustability
Comfort is the key
With 22 mm of handlebar adjustability across four possible positions, three different positions for the brake and shift lever and infinite positioning options for the hand levers, lower foot pegs and adjustable windshield - this is the most ergonomic SPORTS TOURER of all time.
Equipped to go the distance
Terrific touring stamina
With the likes of a 23 liter long-range fuel tank, an easy-to-adjust windshield, integrated pannier mountings that are easily removable, heated grips, long service intervals and race-derived quick shifter; let the race begin.
2017 KTM 1290 Super Duke GT - www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: $ See Dealer for Pricing in USD
Europe/UK MSRP Price: £15999 GBP (On The Road inc 20% Vat)
Engine
" Design
2-cylinder, 4-stroke, V 75°
" Displacement
1301 cm³
" Bore
108 mm
" Stroke
71 mm
" Power in KW
127 kW
" Starter
Electric starter
" Lubrication
Forced oil lubrication with 3 oil pumps
" Transmission
6-speed
" Primary drive
40:79
" Secondary gear ratio
17:38
" Cooling
Liquid cooled
" Clutch
PASC (TM) slipper clutch, hydraulically actuated
" EMS
Keihin EMS with RBW, twin ignition
Chassis
" Frame design
Chromium-Molybdenum steel trellis frame, powder coated
" Front suspension
WP Semi-active suspension USD Ø 48 mm
" Rear suspension
WP Semi-active suspension monoshock
" Suspension travel (front)
125 mm
" Suspension travel (rear)
156 mm
" Front brake
2 x Brembo monoblock four-piston radial fixed calliper, brake discs, floating
" Rear brake
Brembo twin-piston fixed calliper, brake disc
" Front brake disc diameter
320 mm
" Rear brake disc diameter
240 mm
" ABS
Bosch 9ME Combined ABS (incl. cornering ABS and supermoto mode, disengageable)
" Chain
X-Ring 5/8 x 5/16"
" Steering head angle
65.1 °
" Wheelbase
1482 ± 15 mm
" Ground clearance
140 mm
" Seat height
835 mm
" Tank capacity (approx.)
23 l
" dry weight
205 kg
