2017 Victory Cross Country Tour - Coolness Factor = 66.7%
Your Coolness Factor of the 2017 Victory Cross Country Tour
6
50%
4
33%
0
No votes
2
17%
Total votes: 12
2017 Victory Cross Country Tour on the Total Motorcycle Cool Wall
For MORE information and Photos click here: http://www.totalmotorcycle.com/motorcyc ... untry-Tour
2017 Victory Cross Country Tour on www.Totalmotorcycle.com
PACKED WITH POWER...
Cross America in record time. Take the standard Cross Country® bagger - a capable platform for any two-wheeled adventure - hit it with a dose of comfort and convenience features like a 200W eight-speaker Bluetooth® and USB audio system, and what you get is the Cross Country Tour: a V-Twin touring bike ready to go anywhere comfortable and quickly. So set ambitious destinations with the Cross Country Tour®, which offers the largest total cargo capacity on a production touring motorcycle (41.1 gallons). Victory's Comfort Control System provides upper and lower air controls that channel the wind to maximize comfort while a padded passenger backrest, three-position adjustable floorboards and dual zone heated seats give your passengers the control they deserve. An air-adjustable rear suspension further aids rider and passenger comfort while ABS and new LED lighting helps keep your mind at ease.
With a twist of the wrist, the Cross Country Tour® crosses time zones without leaving your comfort zone.
Go Further, Faster.
2017 Victory Cross Country Tour www.Totalmotorcycle.com Key Features
A V-twin touring bike packed with power to go anywhere comfortably and quickly.
• Freedom® 106 V-Twin That Delivers 106 Ft.-Lb. of Torque
• LED Headlight, Bluetooth® / USB Audio & ABS Standard
• Heated Grips & Dual Zone Heated Seats
• Three-Position Adjustable Passenger Floorboards
• 41.1 Gallons of Storage
2017 Victory Cross Country Tour www.Totalmotorcycle.com Features and Benefits
Largest Total Cargo Capacity in the World
Forty-one gallons of storage capacity makes this the most cargo space of any production motorcycle.
Standard LED Headlight
Modern lighting comes standard with a LED headlight that is 74% brighter than halogen bulbs providing all the vision you need at night.
Confidence-Inspiring Brakes
Own the road in any condition. The Victory Anti-Lock Brake System monitors traction to automatically provide control, stopping power, and confidence in any situation.
Victory Comfort Control System
Turn the winds to your favor. Victory’s Comfort Control System provides upper and lower air controls that channels the wind to maximize your comfort.
2017 Victory Cross Country Tour - www.Totalmotorcycle.com USA Specifications/Technical Details
US MSRP Price: Available in Gloss Black ($21,999), Gloss Blue Fire ($22,499) and Two-tone Turbo Silver and Black ($22,999).
Canada MSRP Price: $25,999 CDN
Specifications
ABS/Cruise Control Standard
Curb Weight 876 lbs / 398 kg
Displacement 106 ci / 1731 cc
Oil Capacity 5.0 qts / 4.73 ltr
ENGINE & DRIVETRAIN
Valve Train SOHC - 4 Valves per Cylinder/Hydraulic Lifters & Cam Chain Adjusters
Transmission Type 6-speed overdrive constant mesh
Transmission/Primary Drive Gear drive with torque compensator
Transmission/Final Drive Carbon Fiber Reinforced Belt
Exhaust Dual-Large Bore Slash-Cut with Common Volume
Drive/Driven Clutch Wet Multi-Plate/Diaphragm Spring
Cooling Air / oil
Compression Ratio 9.4 : 1
Charging System 48 amps max output
Battery YTX20HL-BS/12 Volt 18 Amp Hour 310 CCA
Bore x Stroke (mm) 101 x 108 mm
Engine Type Freedom 106/ 6 V-Twin
Suspension
Rear Suspension Single Monotube Air Adjustable Shock: 4.7" (120mm) travel
Front Suspension Telescopic Fork/ 5.1" (130mm)
Brakes
Rear Brakes Dual 300 x 5mm/Floating Rotor/4 Piston Calipers
Front Brakes Dual 300mm floating rotor with 4-piston calipers
Brake System Type Conventional w/ ABS
Tires / Wheels
Rear Wheel 16 x 5.0"
Rear Tires Dunlop D418 Elite 3 180/60R16 M/C 80H
Front Wheel 18 x 3.5"
Front Tires Dunlop D418F Elite 3 130/70R18 63H
DIMENSIONS
Wheelbase 65.7 in / 1670 mm
Seat Height 26.3 in / 667 mm
Rake/Trail 29.0° / 5.6 in / 142 mm
Ground Clearance 5.8 in / 148 mm
GVWR 1360 lbs / 617 kg
Fuel Capacity (Litres) 5.8 gal / 22 ltr
Overall Length (in./mm.) 108.1 in / 2747 mm
Features
Colors (Base) Gloss Black, Gloss Blue Fire, Two-tone Turbo Silver and Black
Color Swatch Gloss Black
Comfort Heated Dual-zone Seat, Heated grips
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
Re: THIS WEEK: 2017 Victory Cross Country Tour - VOTE TODAY
#2 Unread post by Gummiente »
Although I'm not a fan of the angular, Arlen Ness style spaceship styling, this bike has been in my top three list of possible replacements for my Road Glide ever since it was first released. I have a couple of friends who ride them and they are very happy with the quality and performance. It's just too bad that Polaris killed the brand in order to boost sales for Indian. Harley isn't the only company that makes baffling decisions (eg Buell, MV Augusta) like this, it seems.
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
ceemes
Real Name: a big secret
#3 Unread post by ceemes »
meh.....another full bagger....and from a defunct badge.......not voting.
markdcoco
Real Name: Mark DiCocco
My Motorcycle: 2014/BMW/R1200RT
#4 Unread post by markdcoco »
There's got to be a category LESS than "Fail"......... no vote
montanalifter
Real Name: Bill
#5 Unread post by montanalifter »
Would not mind riding around the country on this bike. I voted awesome. Really nice bagger with good power and storage.
JackoftheGreen
Real Name: Eric
#6 Unread post by JackoftheGreen »
It's a beautiful machine for what it is, and someone shopping in this niche could certainly get a lot of use from the platform. Nothing I'd ever buy, so it can't be Awesome, but a solid Cool. Sad to see the Vic line go belly-up, and I'll never understand Polaris making that call, but I'm sure they know more about it than I do.
Gummiente wrote: Fri Jun 30, 2017 11:06 pm Although I'm not a fan of the angular, Arlen Ness style spaceship styling, this bike has been in my top three list of possible replacements for my Road Glide ever since it was first released. I have a couple of friends who ride them and they are very happy with the quality and performance. It's just too bad that Polaris killed the brand in order to boost sales for Indian. Harley isn't the only company that makes baffling decisions (eg Buell, MV Augusta) like this, it seems.
If the 2017 Victory Cross Country Tour is a candidate, it might be a good idea to start looking for a "left over" 2017 model... might be some great deals out there right now...
Gummiente
Years Riding: 38
#8 Unread post by Gummiente »
totalmotorcycle wrote: Wed Jul 05, 2017 8:01 am If the 2017 Victory Cross Country Tour is a candidate, it might be a good idea to start looking for a "left over" 2017 model... might be some great deals out there right now...
Boss, I'm not tired of the Road Glide yet. 127k on my '07 RG and 5k since May on my new RG. Plus, I prefer to own a bike that has a national network of dealers and massive aftermarket support, I'm funny that way. :D
It's THAT you ride
Gummiente wrote: Wed Jul 05, 2017 8:36 am
Wow, nice mileage on the bikes! A little off-topic, but how are you liking the new RG? Would you recommend it versus the 2007?
I'm with you on the national network, although I did go and buy a Guzzi, which doesn't have as big of a network, but it's growing and even in my town of Waterloo, there is a Guzzi dealer 30 mins away so not bad.
I voted: Cool
Personally, I'm not (yet?) into the baggers, although it would be a heck of a lot more conformable on long trips than my naked Guzzi V7. So if I was considering a long tour bagger, I like Victory, so why not? The Freedom® 106 V-Twin is an outstanding engine and I haven't heard anything unreliable about Victory models either.
I'm quite interested in that odd looking blue color version, it looks both "ugh and wow" in the photo, it would be one to see in real life. But that would be the one I'd get. I do GREATLY miss the Victory paint jobs of old, wow, where they something and really set Victory apart from the competition. I'll miss Victory as well, "modern, state-of-the-art, cruiser". Hopefully Indian doesn't rely on it's "heritage" vs innovation.
2017 Victory Cross Country Tour gloss blue fire. Yup, that would be the one I'd get, just love metallic bright colors... especially that Harley-Davidson heavy flake...wow. When I get another bike to replace my Guzzi (one day, that will be hard to do) I'll have to go for a metallic flake pop color or something like that.
Good by Victory, many will miss you... come back soon!
